05-20-2012, 02:40 PM | #1 |
Rep 2,612
Drives: F30 328i Luxury - Sport Auto
The Automatic Transmission learns your driving style.
But how? What does it change? It must only implement its knowledge of the driver in "D" and "DS" musn't it? Can't change much in Manual mode can it!?
What could it learn? I need to learn it firstly! Applies for both Standard Auto and Sport Auto.
Gone: 2006 BMW E60 520d SE 6MT Gone: 2009 BMW E90-LCI 330d SE 6MT Current: 2012 F30 328i Luxury 8AT On Order: 2015 Audi A6 Avant Ultra, Black Edition (sorry!) |
05-20-2012, 04:15 PM | #2 | |
Rep 15,858
This is my understanding after looking at many documents on 'Adaptation' to driver type. It doesn't strictly learn your style, but adapts to, and selects the most appropriate programme to suit how you drive. Change to another style and it adapts within a few seconds, if not instantly if you make agressive inputs, like rapid throttle or brake movements. Each generation obviously gets more advanced features, what the 8-speed has over the 6-speed I've yet to read, but the 6-speed adaptive features are well documented. For the 6-speed autos, the driver-type adaptation is restarted each time the vehicle pulls away from a standstill. So nothing in memory. HighlandPete |
05-20-2012, 04:23 PM | #3 | |
Rep 2,612
I suppose the driving mode (Eco Pro, Comfort, Sport, Sport + - the name of the button has just escaped me - Drive Performance Control? Mind blank!) will manually influence the transmission adaptation.
05-20-2012, 05:01 PM | #4 | |
Rep 15,858
I've got a feeling the subtle differences will mean a very sensitive driver will feel his/her car is behaving differently every time you drive, according to what you switch/configure and if you adjust your style a bit. Personally not to sure on "transmission control with foresight" if it is more advanced than the "cornering detection" that I have in my 6-speed. HighlandPete |
05-20-2012, 06:35 PM | #5 | |
Rep 1,684
05-20-2012, 07:38 PM | #6 | |
Rep 545
As the transmission friction clutches wear the “fill time” for the shift to complete will change, but with the “self-healing” ability the transmission should shift the same. When the transmission is replaced or rebuilt the adaption values are cleared to allow the ECU to begin the correction process again and the transmission will go through the “relearn” process. Through the process of sensing and adjusting the ECU will create adaption values to allow the transmission to shift consistently during its life. Having electronic pressure control also allows the transmissions to have several personalities with the push of a button, movement of the shifter, or full throttle signal. The old days transmissions only used two inputs, Vehicle speed and Load (throttle position) which didn’t provide much adaptability. If you wanted a snappy shifting transmission you had to install a shift kit and live with that mode…..today you can just select the mode for your mood. See also: http://www.thetruthaboutcars.com/200...transmissions/ Ken Welch Instructor Automatic Transmissions Saddleback College |
05-20-2012, 09:34 PM | #7 |
Rep 545
Here is another link for more infomation:
http://www.bimmerboard.com/forums/posts/713335 |
05-21-2012, 06:31 AM | #8 | ||
Rep 2,612
Tags |
automatic, f30, sport, standard, transmission |
