Go Back   M3Post - BMW M3 Forum > M3 Marketplace > SPONSORS Classifieds/Groupbuys/Specials Area > Suspension | Brakes | Chassis | Handling
      07-31-2014, 12:16 PM   #1
jeff@autocouture
jeff@autocouture's Avatar
966
Drives: 2002 E53 X5 4.6is
ACM | Ohlins Road&Track 2017 Specials
Contact me for all install specials!
For those of you out of the area pm me for promotion pricing shipped
This is the latest step in the Ohlins Racing automotive philosophy – Road&Track by Ohlins. A more than 30 year long tradition of high-end racing commitments and state-of-the-art solutions within advanced suspension technology is now available for street cars all over the world. The focus has been clear from the very beginning – superior road handling without sacrificing comfort in your day-to-day transports. The time of compromises are over!
Ohlins has added a clever light-weight design with a majority of the parts in aluminum. On top of that, all shocks have suffered through vast corrosion tests according to ISO 9227. The end result is a 2-year limited warranty on all of our products - worldwide.
The Features of DFV Technology
So what is DFV? It is Dual Flow Valve technology – and it sets us apart from our competitors. Only Ohlins has DFV technology on its road and track products.
With DFV, the dual flow valve gives the same characteristics on rebound as it does on compression, thanks to the damper fluid having a consistent path of flow in both directions. This means that the wheel and tyre can quickly and effectively resume their important position back on the ground, providing grip and traction. The new Öhlins R&T range uses DFV technology on every single fitment, making it the perfect upgrade for the enthusiast that needs comfort and agility in the one unit.
Figure 1: (Compression flow) At low shaft speeds, oil flows mostly through the shaft jet bleed (lower dotted arrow). At higher shaft speeds, oil flows mostly through the compression ports in the piston (upper dotted arrow). At very high shaft speeds, or during sudden shaft accelerations, oil can also escape through the compression ports in the DFV, increasing comfort. Figure
2: (Rebound flow) At low shaft speeds, oil flows mostly through the shaft jet bleed (lower dotted arrow). At higher shaft speeds, oil flows mostly through the rebound ports in the piston (upper dotted arrow). At very high shaft speeds, or during sudden shaft accelerations, oil can also escape through the rebound ports in the DFV, maintaining tyre contact with the road.
Because DFV opens more quickly and easily on minor road imperfections, ride comfort is surprisingly supple and more akin to an OEM strut than a coilover set-up. Over undulating surfaces, the compliancy of the R&T units allows the car to crest bumps and pot-holes, whilst still keep stable and in control. Traction is always maintained at its optimum level. When comparing suspension, why settle for second best?
Figure 3: (Vehicle – no DFV) Without DFV the oil can not flow through the piston quickly enough on the rebound stroke after hitting a bump, so the tyre is not able to stay in contact with the road.
Figure 4: (Vehicle – DFV technique) The DFV valve opens, letting the oil flow quicker through the piston on the rebound stroke after hitting a bump, enabling the tyre to stay in contact with the road.
When adjusting ride height on coilover units, it’s worth comparing how it’s done. On many inferior designs, height is adjusted by raising or lowering the lower spring platform. This has the effect of compressing or extending the spring, which can limit the suspension travel that may cause topping out. The Öhlins method is to leave the spring seat in its perfect position, whilst the lower flange spins easily on the threaded body, to allow you to adjust with absolute precision whilst maintaining the perfect characteristics that we took so long to design in! Once you’ve set it all up, the adjuster simply locks off to maintain your exact settings.
Dampers will get hot. That’s one thing that you can be sure of. As the piston moves within the damper, it generates friction – and therefore, heat. Although we can’t stop heat, we can deal with it, and this is yet another way that Öhlins differs from the competition. As the heat increases, the viscosity of the damper fluid can change, altering the car’s handling characteristics. Our unique needle bleed valve expands with temperature, closing the gap that the fluid travels through, maintaining a consistent damping rate. The best thing of all? You won’t even notice! All you’ll feel is that the car responds consistently, lap after lap, turn after turn. Allowing you to concentrate on braking points and apexes whilst the Öhlins technology takes care of the damping.
Figure 5: Thermal Expansion
These kits all work well ‘out of the box’, but there’s still plenty of adjustment for you to set things your way. You like stiff and reactive? Or soft and forgiving? It’s all there. Too much low speed rebound damping can have an adverse effect on grip, so the easily accessible adjuster at the base of the Öhlins units allows small, but positive increments of fine tuning, so you can take into account every single parameter. Sounds complicated? Nothing could be further for the truth. Just a few clicks either way from our factory settings will soon have your car responding precisely to your inputs and driving style.
The Road & Track McPherson struts also feature camber adjustable upper and lower mounts to give you the possibility to fine tune your wheels for the right occasion – whether you want to go for a ride in your neighborhood or take your car for a spin at the track on a weekend.
Features:
- DFV (Dual Flow Valve)
- Adjustable ride-height
- Fully rebuildable
- Corrosion salt spray tested (ISO 9227)
- Includes hardware and installation instructions
- 2 year Limited Warranty
Front:
- McPherson Strut
- Single bleed adjuster
- Spring preload adjuster (approx. 15 mm lower than standard)
- Coil Springs
- Dustcovers
- Uses original top mounts
Rear:
- Conventional Shock Absorber
- Separate spring preload adjuster (approx. 15 mm lower than standard)
- Coil Springs
- Dustcovers
Applications
2001-2006 BMW E46 M3 - F: 60 N/mm(343 lbs/in.) R: 70 N/mm(400 lbs/in.)
2006-2012 BMW E9X 3-Series - F: 70 N/mm(400 lbs/in.) R: 110 N/mm(630 lbs/in.)
2008-2013 BMW E9X M3 - F: 60 N/mm(343 lbs/in.) R: 120 N/mm(686 lbs/in.)
brembo
ohlins
gwb
Contact me for special in house installs and our free shipping deals!
Alex
      07-31-2014, 12:41 PM   #2
jeff@autocouture
966
E93 M3 Ohlin Equipped
      07-31-2014, 03:50 PM   #3
CIFUM3
CIFUM3's Avatar
Drives: 08 E92 M3
Price shipped to 85233? 2008 E92
Performance
ESS 625 VT2 Supercharger - CAE Shifter - Revinora race+ axle back - Macht Schnell down pipes - SOSI X-pipe
Looks
M colors grill - CF trunk - Sapphire Blue Forgestars F14
      07-31-2014, 04:20 PM   #4
jeff@autocouture
966
pm on the way
      07-02-2015, 02:33 PM   #5
jeff@autocouture
966
Pm me for special pricing
      08-25-2015, 05:46 PM   #6
jeff@autocouture
966
still going! kits being sent out, pm me for a deal today!
      08-25-2015, 06:29 PM   #7
SSJVegita
SSJVegita's Avatar
Drives: E92 BMW M3
im in nj, pm me deals plz
      08-25-2015, 06:37 PM   #8
jeff@autocouture
966
pm sent!
      09-14-2015, 12:39 PM   #9
jeff@autocouture
966
Bump! pm me for special pricing
      10-09-2015, 12:11 PM   #10
jeff@autocouture
966
All pms sent!
Contact me for the best deal
      10-14-2015, 09:49 PM   #11
SSJVegita
SSJVegita's Avatar
Drives: E92 BMW M3
pm with best deal
      10-18-2015, 05:00 PM   #12
NiCe93
Drives: 2011 e93 M3
In NJ, please PM me pricing for e93.
      10-19-2015, 01:00 PM   #13
jeff@autocouture
966
pms sent!
bhup0925.00
      10-21-2015, 01:23 PM   #14
jeff@autocouture
966
pms sent and kits shipping out!
      10-21-2015, 01:48 PM   #15
SpacegrayMe90
Drives: 2010 e90M3
PM your best price
      10-27-2015, 05:22 PM   #16
jeff@autocouture
966
all pms answered!
      11-02-2015, 02:29 PM   #17
jeff@autocouture
966
all pms sent, pm me for great pricing!
      11-06-2015, 11:55 AM   #18
jeff@autocouture
966
all pms sent!
All systems ready to ship!
      11-10-2015, 07:57 PM   #19
jeff@autocouture
966
all pms sent and kits shipped
get yours today!
      11-11-2015, 04:03 PM   #20
Matt@AUTOcouture
Matt@AUTOcouture's Avatar
4164
Drives: V8 tricycle
I have Ohlins on mine as a daily driver and I absolutely love it. So comfy on the freeway, but then I go play with it in the canyons. Only been out to 1 track event on them, but they performed great.
      11-16-2015, 04:45 PM   #21
jeff@autocouture
966
all pms sent, pm me for some early black friday specials!
      11-18-2015, 08:34 PM   #22
Ultra M
Ultra M's Avatar
Drives: [09 E90]
pm me the price for early black Friday special please !
