08-05-2008, 08:23 PM | #1 |
Rep 10,407
19" Wheels - Minor Scuffs and Great Repair Procedure
Well the time had to come, if you drive your car "normally" are often in a hurry and parallel park sometimes, I think some wheel scuffs are pretty much inevitable. They were at least for me . I scuffed the right front then about a week later the right rear. I wish I had some before and after pictures but was so pissed and in a hurry to get a fix done, I don't. These were my first two scratches on my new baby and I'm sure you can relate to that sinking feeling when you hear and feel your wheel grind on a curb. Even a pretty minor scuff makes a terrible noise and sensation. Despite not having pics you'll have to trust me this worked KILLER. If you are a perfectionist - the kind that will examine his/her wheels with a microscope and obsess over anything less than a perfect and new looking wheel, forget it. You'll have to have the wheel entirely professionally refinished to get back to there. This gets you 90% of the way there with about 30 minutes of easy do it yourself work.
A bit more about the scuffs. Mine were only about 1" or so long. They had paint transfer from the curb as well as clear coat removal and some fairly deep gouge/scratches in the alumimum itself. Although not terrible I kind of felt that cosmetically my wheels were ruined. Man was I kicking myself in the ass... This works particularly well in two cases. 1. With 19 inch OEM wheels. Why? Because they are basically a polished aluminum finish, which will match the raw aluminum finish you get with these steps. 2. With fairly light gouging of the aluminum. It should be painfully obvious but do not use this procedure if you do not have at least some gouging/scratching in the aluminum itself. If you have escaped with just paint transfer or lighter scratches you could try either just the rubbing compound or the 600 grit + rubbing compound. Steps:
The only remaining step will be to finds a suitable clear coat that can be brushed on. Almost everything "off the shelf" in a spay can will be not nearly durable enough for a car wheel. Any suggestions here on a good material for the clear coat is welcomed. I truly hope this makes at least one of you feel very relieved at your carelessness in banging up your beautiful 19s on your M. Enjoy. |
08-06-2008, 03:05 PM | #4 |
Commander-In-Chief
2122
Rep 8,923
Drives: 2023 M2 Coupe, 2020 GLE 450
BMW touch up paint comes in a 2-pack with clear as one part of the set.
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 |
08-06-2008, 04:07 PM | #5 |
Rep 1,844
Thanks for this. I scuffed one this weekend and agree that it almost physically hurts when you do it. Glad to hear that this turned out well and I plan to give it a try.
08-06-2008, 04:31 PM | #6 |
Rep 10,407
08-06-2008, 06:25 PM | #7 |
Rep 2,937
Drives: 2013 Estoril 328i M Sport
Nice writeup Marshall. I scratched my right rear wheel up two months ago while talking to my mother on the phone. Twas' a sad day.
08-07-2008, 09:40 PM | #9 |
Rep 5,498
Nice write-up....on that note my E36's wheels are bare aluminum with a little off the shelf clear coat. However, the clear coat is mostly gone now and I am seeing some staining now. You will need something really strong to hold up and I will be interested to see what you come up with!
Jason
Instagram: jellismotorwerks |
01-08-2009, 09:02 PM | #11 |
Rep 361
actually ... this does NOT work. It turns out on my 09 BMW M3 the 19" wheel surface is painted (and clear coated)... it looks like naked aluminum, but it's not... there is definitely a paint, duller/greyer/silver than aluminum.
This procedure by the OP is great, but it only preps you for a real paint application afterwards. I am just going to have the body shop do it. |
01-16-2009, 08:55 PM | #12 |
Rep 10,407
Depends on your standards. -It certainly is true that th OEM 19s are painted and clear coated. The whole reason this works pretty well for MINOR scuffs is that this combination of paint and clear looks very similar to polished aluminum. -This is clearly a good alternative in terms of price/cost/effort to a full wheel refinish. |
01-16-2009, 09:36 PM | #13 | |
Commander-In-Chief
2122
Rep 8,923
Wheel repairs
01-16-2009, 09:58 PM | #14 |
Rep 2,278
I have scuffed the wheels of my e46 M3, and my 550 with M5 (style 166) and others. I had "the wheel guy" I was referred to by my SA repair them and he was mobile. Cost about $50 wheel and a very good job. You would really have to examine the wheel closely to tell there was any damage, and even then you might not detect it.
2015 f80 M3, 2016 GT3
01-19-2009, 11:42 PM | #15 |
Rep 4,318
This is a great quick way to at least smooth things over, thanks swamp.
The link below contains a detailed run through of a more involved process. Not sure I would want to attempt it but it looks like for the more patient perfectionist that doesn't want to go to the wheel shop that it would get you more "finished" results. http://www.audiworld.com/tech/ext43.shtml |
