Tirerack
Use the following links to go directly to useful tirerack winter items: Tirerack Winter Tires. Gary's Winter Tire FAQ.
Using the links directly supports E90Post with tirerack sales commision!
  E90Post
The Tire Rack
   PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS!
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Style 230 on 2010 323i?
Wheels and Tires forum Sponsored by The Tire Rack
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer
      02-05-2024, 12:30 PM   #1
matt.zahorec@gmail.com
Drives: BMW E90
Hey there, I know it's been done before but I want to put style 230s on my 2010 323i.
The two options for tire setups I have are: Fronts 225 40 19 Rears 265 30 19.
and Front 225/35/19 Rear 255/30/19
Which would be better to run these on an e90?
Thank you for your help.
      02-05-2024, 01:43 PM   #2
tcphoto
tcphoto's Avatar
Drives: E92 335i 6MT Coupe
The 235/40/19 and 265/35/19 will give you a bit more aggressive look and not so firm ride, hit a couple potholes on a 30 profile tire and see how pleasant it is.
      02-06-2024, 05:59 AM   #3
wrevilo
Drives: 2010 E92 335i N55 6MT
Surely a 40 profile at the front is going to be too big?
I run 235/35 at the front and 255/35 at the rear. However, in future I will run 265/30 at the rear.
      02-06-2024, 01:14 PM   #4
vester86
Drives: BMW 330D '08
the second option is stock e90 sizes and therefore perfect fitment.
the first option has quite a big difference between front & rear. front is way too big.
what you could do is 235/35/19 which is 1 size wider then stock.
the suggestion tcphoto gives is too big (both wide AND height) so your speedo will be off quite significant and possible rubbing
e90post
