      01-27-2015, 10:16 AM   #1
surlynkid
surlynkid's Avatar
115
Drives: 2013 E92 M3
Solo DL mount without suction cup
LSR PCA just outlawed suction cups - every single kind. Who has options for mounting an AIM another way that requires no drilling.
      01-27-2015, 12:18 PM   #2
z3papa
Drives: 11 E92 M3 ZCP, 07 335i
While I can marginally understand the ban on suction cups which can't hold, it's a bit over the top as I've had several setups which hold exceptionally well including one three cup version you could pick up 50 lbs with.
Sold 2011.5 E92 M3 ZCP.
      01-27-2015, 01:43 PM   #3
PrimeBMW
PrimeBMW's Avatar
Drives: E46 M3+S62, E92 M3
You might try calling Ram Mounts. rammount.com 1-800-497-7479 They might have some ideas for you.
      01-27-2015, 02:00 PM   #4
mid-corner fun
Drives: F80 M3, '22 X3MC
Here's my no-suction-cup setup, works great. 2 tie-wraps through the air vents hold the base plate in place.
      01-27-2015, 05:28 PM   #5
surlynkid
surlynkid's Avatar
115
Drives: 2013 E92 M3
Thanks mid-corner. That was the kind of idea I was looking for. The tie raps don't interfere with the magnets getting the AIM flush against the base?
      01-27-2015, 05:40 PM   #6
Estoril Blue
Drives: 2006 M3
      01-27-2015, 05:50 PM   #7
mid-corner fun
not at all, and I used regular-size tie-wraps. The only downside (if it even matters) is that it's easier to leave the base there for the whole track season instead of looping/cutting tie-wraps each time.
The screen is visible from both seats so I usually use predictive when driving alone and switch to a custom gear/rpm/temps display when I have a passenger.
      01-27-2015, 08:27 PM   #8
ThunderMoose
Mine is mounted with magnet double sided tape to aluminum L that is riveted to air duct. You could do something similar and it would be invisible if you decided to sell the car.
      01-28-2015, 10:28 AM   #9
surlynkid
surlynkid's Avatar
115
Drives: 2013 E92 M3
Estoril - where did you get that bracket? Is that an E46? I have seen some brackets for E92's but oddly they very specifically say for aluminum finish trim or woodgrain finish trim only. I have the fake carbon fiber look trim.
      01-28-2015, 10:48 AM   #10
Estoril Blue
Drives: 2006 M3
Its a Pro Fit. Yes - E46.
      01-28-2015, 11:32 AM   #11
surlynkid
surlynkid's Avatar
115
Drives: 2013 E92 M3
I had already looked at pro fit. Nothing M3 specific.
      02-08-2015, 08:43 PM   #12
tlp
Drives: 991 GT3, Sold:'11 e92 M3 SG/FR
That sucks!!...No pun intended.
In your case then suction cups should be legal as long as they are tethered? Maybe you can fashion a leash somewhere. Are you mounting it on left or in the center? The DL cable connection itself is already a quasi-leash.
991 GT3, Sold: '11 e92 M3 SG/FR ZCP|ZCV|ZP2|2MK|494|415|6NR|752
