11-07-2014, 07:06 PM | #1 |
Rep 242
Repair or Total?
Long story short: My insurance wants to Total my car, but At fault insurer wants to repair. What do you guys think?
11-07-2014, 07:10 PM | #2 |
Rep 5,506
It's up to you... your car will be worth less even if the repair is perfect. But if you really like the car, plan to keep it for a long time and don't care about your car being worth less, you can fix it and drive it.
If you total it, you get a check for the car and you can go buy another one which may be in better condition.
Auto Detailing Enthusiast!
11-07-2014, 08:20 PM | #6 | |
Rep 701
The only way to know is when you strip the front end. Dollars to donuts the subframe is shot, the steering rack and probably the right side frame rail. That by itself is close to $8K in parts and labor. That's before you even get to body panels and paint, and of course see what else is broken underneath. |
11-07-2014, 08:30 PM | #7 | |
Rep 3,633
11-07-2014, 08:32 PM | #8 |
Rep 3,633
And yes that loss appears more cosmetic from photos alone and the balljoint will break like that upon impact. Doesn't mean it was a super hard hit. The rt upper rail looks ok, but again the car needs an in person appraisal versus the experts here.
11-07-2014, 08:45 PM | #10 |
Rep 139
Hard to tell from the photos (though you did a good job of providing them). The bodyside, door, fender, fascia all need serious work - front suspension as well obviously. The real question is how much you got into the body structure on either side of the door, as well as the chassis subframes and their mounting points. Did the airbags deploy?
In any case that's a lot of damage - I'd be crossing my fingers they total it. Best of luck. |
11-07-2014, 08:51 PM | #11 | |
Rep 701
Trying to wish a car not to be totalled, when it should be totalled makes no sense. |
11-07-2014, 08:53 PM | #12 |
Rep 701
Wrong. If you have ever fixed a BMW through a BMW approved shop, (I have) you would know that the steering rack MUST be replaced. It's a safety issue. If you fix the car through some fly by night shop then you can do whatever you want I guess.
11-07-2014, 08:57 PM | #14 |
Rep 116
Insurance companies these days can and will use aftermarket parts , I've even seen used when new can't be stocked for reasonable price. If the subframe is compromised, they will definitely quote out a new one though - I already tried finding a used one before, it's nearly impossible since its specific to manual or DCT. My opinion is that it's body work, control arms, axle, wheel, tire, etc but not subframe. Rack, maybe. They sometime just quote out tie rods believe it or not
11-07-2014, 09:05 PM | #15 | |
Rep 3,633
And if you want to compare resumes, I worked at one of the highest volume BMW repair facilities in the northeast. I'm also ppg, chief certified and a high end appraiser. The point was that it's hard to estimate from pics alone. |
11-07-2014, 09:07 PM | #16 |
Rep 701
Something to consider is if the car is leased or financed he can't use any aftermarket parts.
I went through a similar wreck and it was right on the margin of being totalled but they ended up repairing it. They used all BMW parts and it was a small fortune. At this point I hope the OP does fix it. I am intently curious to see what he has going on there and what they quote him. |
11-07-2014, 09:08 PM | #17 | |
Rep 3,633
11-07-2014, 09:12 PM | #18 |
Rep 3,633
Third party can't use aftermarket parts on his repairs and they are slim pickings cause it's an m3. Same with used parts.
Good luck op whatever happens! At least you're ok |
11-07-2014, 11:06 PM | #19 | |
Rep 242
Thanks!
11-07-2014, 11:19 PM | #20 |
Rep 12,726
I would look carefully at the suspension mounting points before making a decision. If they are damaged, total it. If it's just body work, your call.
11-07-2014, 11:59 PM | #21 |
Rep 3,633
Wow. That was def a good hit then. In that case they may total it and you'll feel better and just get another!
11-08-2014, 12:00 AM | #22 |
Rep 3,633
