  TireRack
      11-17-2014, 10:30 PM   #1
grantmax
Drives: 2011 M3 ZCP
Anyone have the "hub fitment" issue with Turner 10mm spacers?
Turner has the whole "10mm spacers might not fit properly on your hub" warning on their site.
1. Is anyone using TMS 10mm spacers? If so, any issues?
2. Has anyone tried to fit TMS 10mm spacers and encountered fitment problems?
      11-17-2014, 10:38 PM   #2
m3ray
Drives: '09 e92 M3
Best to use the 12mm if you can. FWIW I have the MS 10mm with no bottom out on the hub.
      11-17-2014, 10:43 PM   #3
grantmax
Drives: 2011 M3 ZCP
Have 12s but would prefer 10s. I've seen some "no problem" posts regarding TMS as their 10s have the hubcentric lip. Just doing a little DD before making the purchase.
      11-17-2014, 10:43 PM   #4
Denk
Denk's Avatar
Drives: '18 M240xi
TMS 10mm sit flush on the hub and flush on 220/359 OEM wheels. The same for MS 10mm.
      11-18-2014, 03:02 AM   #5
grantmax
Drives: 2011 M3 ZCP
So I'm good with ZCPs.
Thanks
      11-18-2014, 01:04 PM   #6
Denk
Denk's Avatar
Drives: '18 M240xi
Thanks
Yes, the chamfer design on the TMS 10mm allow them to sit flat on the hat on the OEM wheels. They didn't work on a couple of aftermarket wheels though.
      11-18-2014, 03:37 PM   #7
Hujan
Hujan's Avatar
Drives: 2013 E92 M3
I had zero problems running 10 mm spacers on my ZCPs in the rear. They seemed to fit as snugly as the 12.5 mm.
Fit 275/35-19 PSS tires with no rubbing as well.
I have a set of BNIB 10 mm TMS spacers if anyone is interested. Lug bolts, too.
E92 M3: MRF Velaforza | Brembo GT | KW Clubsport | BBS E88 | Recaro Sportsters
Search this Thread:
Advanced Search
