  TireRack
      07-24-2014, 11:29 AM   #1
IL8Apex
IL8Apex's Avatar
Drives: 2009 E92 M3, 1999 E36 M3
Tire Cupping - Is it the alignment?
Front tires Bridgestone S-04 255/35-19 are cupped pretty badly after about 10K street miles. Rears are fine. I have Dinan springs with Dinan camber plates.
Alignment settings:
Front Left: Camber -2.2 Toe 0.02
Front Right: Camber -2.1 Toe 0.03
Front Cross camber -0.2, cross caster 0.1, total toe 0.05
Rear Left: Camber -1.3 Toe 0.07
Rear Right: camber -1.4 Toe 0.08
Rear cross camber 0.0, total toe 0.16, thrust angle -0.01
The Bridgestone have never been to the track, I have track tires for that. Can the alignment experts find the culprit? Too much negative camber? Toe settings?
2009 E92 M3 / DCT / AW / Black Extended / Akrapovic Evolution / BPM Engine+DCT Tune / Dinan Stage I + Camber Plates / HRE C20 / Valentine One by Alekshop
      07-24-2014, 12:56 PM   #2
smmmurf
Drives: GT4, C2S, E90,46,&E36M3, S2000
That is more camber than a normal street alignment, but it isn't excessive.
When you said cupping, do you mean the inner shoulders? 10K miles is pretty short for front tires with no track use on S04's/PSS/PS2/etc.
The outer shoulders should be in great shape with those specs unless you're cornering hard very often on the street.
M3 Sedan - AW/Black - 6MT - no moonroof - no folding seats - RAC RG63 - clear bra by Omega Werks
      07-24-2014, 01:17 PM   #3
pkimM3r
pkimM3r's Avatar
133
Drives: m3 saloon in granny mode.
camber and toe look fine.
sometimes its the most obvious thing....tire pressure? over inflated?
      07-24-2014, 02:19 PM   #4
SenorFunkyPants
SenorFunkyPants's Avatar
United Kingdom
209
Drives: 2017 M4 CP DCT
      07-24-2014, 04:46 PM   #5
IL8Apex
IL8Apex's Avatar
Over-inflation....I was running 38psi all the way around for most the life of tires, until I backed down to 36 recently. Maybe this is the problem.
I just had my mechanic do a thorough inspection of the suspension and that appears to be fine.
      07-27-2014, 05:43 AM   #6
SenorFunkyPants
United Kingdom
209
I don't think a couple of psi is going to make a difference to the way the tyre wears.
      07-29-2014, 05:02 PM   #7
kenwelch
Drives: 2008 E92 M3 M-DCT & 2017 440GC
Agree, it is usually tire balance.
      07-30-2014, 08:16 AM   #8
ben@tirerack
M3Post Supporting Vendor
47
Drives: 740i
Might help to post some photos of the tires. A visual of exactly what the uneven wear pattern is could give some clues as to the problem.
_______________________________________________
I have accepted a new position at Tire Rack and am no longer in the sales department. gary@tirerack.com is available to assist with M3 questions.
      11-13-2014, 08:44 PM   #9
coolioj
Drives: e46 2002 330i
On my e46 chassis, my cupping was due to a worn FCAB. Replacing that fixed my issue.
Search this Thread:
Advanced Search
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
