06-30-2010, 12:02 PM | #1 |
Rep 3,668
I can not get the side gills out!!! SOS
Hello,
Before i get attacked, yes ive searched. I tried to do the pull up method and no luck at all. I tried to put a tape and yank it with a thin screwdriver and no luck, im too scared to do it harder as i feel like the paint will get messed up. WTF do i do? i feel like its glued in or something. My friend told me to tape it up put a towel on it and yank it out with a plyer. What to do? |
06-30-2010, 12:35 PM | #3 |
269
Rep 6,093
Drives: E90 M3
Location: 1460 White Oaks Rd. Suite F Campbell, CA 95008
07-01-2010, 03:49 PM | #5 |
#thatsanicemovebro
202
Rep 3,920
Drives: E92 M3 LSB/Black 6MT
I had the same problem, took a friend and I almost 2 hrs to remove them.
We used a pry-tool on the top and bottom, both covered with a rag to protect paint. We pushed those in top and bottom to somewhat disconnect the gill, and I was using a flathead @ the edge to pull up. It worked...after a while. Good luck - 2011 fitment seems too good hahaha |
07-01-2010, 10:08 PM | #6 |
Rep 869
I had trouble at first. The pry-tool idea was a total bust for me (you will break or scratch car eventually).
What worked quite easily for me was to pinch the gill tightly and ROTATE it down (or up), as you pull it out. Can't just pull it straight out.
2008 M3 Coupe / DCT // StopTech BBK 380/355 / Pagid RS29 / Motul / Apex Arc-8 / BFG R1S / Ground Control / MS filter / Performance spoiler / BPM tune // Road Atlanta 1:39.70 / VIR Full 2:10.87 / Barber 1:42.20 |
07-02-2010, 04:05 AM | #8 |
Rep 2,441
We got it out today, I got to say, I have removed many of these, for some reason his passenger side seemed to be in there super tight, I was very shocked how hard it was to remove it, the OP wasn't doing anything wrong, this was honestly one of those weird one off cases.
07-03-2010, 08:43 AM | #9 | |
Rep 87
07-05-2010, 10:58 PM | #10 |
Rep 3,488
Drives: Teh Space Gray E92 M 6MT
Lol I just had my meathead homie yank them out with the pinch and pull method. He literally got them off in 2 minutes!
07-25-2010, 10:52 AM | #11 |
Rep 148
If you open the door there is a little hole right from behind where the gill ends (oposite from the M symbol) where you can put a "hookie thingy" through and pry them out...
five seconds work and no chance to mess up the paint or anything... this is how they remove at the factory. |
07-25-2010, 11:24 AM | #12 |
Rep 4,144
Pry up from rear end first. Once it's levered out no more than a millimeter or two the rest of it comes off easy with no tools, just don't try to take it completely off from the back end first. I do recall that the passenger side was a bit harder than the driver side.
Cheers.
2017 F80 YMB.
08-02-2010, 03:39 PM | #13 |
Rep 13,583
Drives: JB E92 335i
They are a bit of a PITA to uninstall and the trick is don't be worried to use a bit of force. This youtube, video is a great DIY and so long as you familiarize yourself with it you should have no problems whatsoever.
[u2b]<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/jHMtTQ50B5g&hl=en_US&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/jHMtTQ50B5g&hl=en_US&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>[/u2b] |
