11-25-2021, 04:39 PM | #1 |
Rep 6
why is my m3 stuck on a power loop?
Good evening all, first off happy thanksgiving.
so im having a problem with my e92 m3. for some reason it keeps "power cycling" as I call it. I new I had a bad battery so I replaced that and still have the problem. car turns on fine but just the electrical system keeps cycling. I can rev it but needles won't move, I-drive goes on and off etc. so I looked through the forums and I saw people suggest it might be a bad JBE so I got a new one installed it today and still having the problem. what am I missing? what else could be wrong. I read somewhere that bad throttle actuators can cause the electrical system to go crazy but before I go and spend that money I wanted to get some more help/insight. you help is much appreciated |
11-25-2021, 04:48 PM | #2 | |
Rep 1,106
DrFerry6728.50 |
11-25-2021, 05:04 PM | #3 |
Field Marshal
6729
Rep 1,829
Drives: '08 E92 M3
Wasn't there a recall on the fusebox ground and the battery cable to the fuse box because of similar symptoms. Shake the fusebox a little by bumping and taping it and see if things come back to life. Search the forums using Advanced Search for Fusebox and Battery Cable ground recalls. There's also the RBS (?) batter stabilizer connector (small connector with the blue wire near the battery) that can be problematic if the connection isn't secure, the wires are bad or the RBS itself went south. You're welcome. Good luck.
///M Power-Belgium63421.00 |
11-25-2021, 05:15 PM | #4 |
Rep 6
I replace the JBE with a new one that I got today. and still having the issue. I use the Carly app (yeah I now its not that great of a scanner ill get my other scanner tomorrow and check ) to check codes and it giving me a bunch of random codes like one that stood out to me was it was saying there was a misfire in 6 out of 8 cylinder. when the car is running fine. ill have to check tomorrow with my other scanner to see what's its throwing.
DrFerry6728.50 |
11-25-2021, 05:20 PM | #5 | |
Rep 6
I out the new battery and was trying to register it using the Carly app. but ran into error etc. then I cam across a thread on here talking about how they themselves had issues registering batteries using the Carly app. ill try registering it tomorrow using my big scanner and also try out what you suggested and let you guys know. |
DrFerry6728.50 |
11-25-2021, 05:29 PM | #6 | ||
Field Marshal
6729
Rep 1,829
Drives: '08 E92 M3
11-25-2021, 05:30 PM | #7 | ||
Rep 1,106
Check all your engine bay grounds and for sure check the fuse box like drferry suggested |
DrFerry6728.50 |
11-28-2021, 04:28 PM | #8 | |
Rep 6
11-28-2021, 04:52 PM | #9 | ||
Rep 1,106
12-28-2021, 05:34 PM | #10 |
Rep 553
Are your needles jumping around? Is the Idrive screen going in and out? If so tell me do you hear a clicking sound near the fuse box or the trunk? If so report back.
Daily: 2010 Venza
Grocery Getter: 16 Q50 Red Sport Track: Top Gear or Grand Tour Concealed Weapon: 11 BMW e92 M3 DCT ESS G1 |
01-20-2022, 06:38 PM | #11 |
Rep 6
yeah needles are jumping around and idrive and ac unit goes in and out. I hear a clicking sound by the fuse box
01-23-2022, 02:13 PM | #12 |
Rep 553
It sounds like a relay. If you can, find the relay that is clicking and pull it out. Then start the car ( the idrive should not flicker or needles should not jump). Replace the relay, if it repeats then there is another electrical issue that need to be sorted. But finding that relay that's clicking is a good place to start. Please report back
Daily: 2010 Venza
01-25-2022, 09:48 PM | #13 | |
Rep 20
but I want to take the time to thank everyone that helped trying to figure out. |
01-26-2022, 12:54 AM | #14 |
Rep 1,047
Interesting conclusion. Having one of those boxes in the system is always suspect when things around it start misbehaving. Good detail to include.
