11-03-2021, 07:46 PM | #1 |
F15 daddymobile
2350
Rep 3,510
TCU? MULF2? no bluetooth
My 08 started showing the no SOS alert at start up and then i noticed my bluetooth doesn't turn on. From a quick search, i thought it was the TCU so i replaced it. Still no bluetooth. Could it be the MULF? where else should i check? Carly app doesn't show shit.
here's my symptons: no bluetooth no phone pairing SOS failure alert chimes and all other alerts work fine USB in center console does not work. EDIT: i've replaced both TCU and MULF and still no luck.
11-27-2021, 01:57 PM | #2 |
F15 daddymobile
2350
Rep 3,510
I've now replaced the TCU and MULF with no luck.
02-10-2022, 11:02 AM | #3 |
Rep 833
Drives: BMW F36, E36, E93
Did you get any further? I've got the same symptoms
Such Fun
If you finde any spelling mistakes in my posts you may keep them, no return required |
02-11-2022, 08:57 AM | #4 |
F15 daddymobile
2350
Rep 3,510
nope still haven't fixed it
02-23-2022, 09:18 AM | #6 |
Rep 833
Is this what you meant?
Such Fun
If you finde any spelling mistakes in my posts you may keep them, no return required Last edited by BWbimmer; 02-23-2022 at 09:39 AM.. |
02-23-2022, 12:15 PM | #7 |
Rep 426
Under the steering wheel/footwell there's a plastic cover that you take off there's some wiring on the left side make sure that everything is plugged in. (Not the ones that power the lights underneath) I had the same issues to find out that I forgot to plug in some connector
