      06-27-2018, 04:26 PM   #1
codinge90
Drives: e92 M3
Brake Force Display Coding Help
Has anyone been able to successfully enable Brake Force Display on an frm2 car? I have a 2010 BMW M3 Coupe and I've read so many posts on the forums about brake force display but not 1 has been able to clearly give steps or an answer to how exactly to enable it on an frm2 car. I will list what I've enabled below and if anyone can chime in and let me know what else to enable or disable to make it work that would be much appreciated.
Add VO $5AB, FA Write it to FRM module
BFD_1_ALGORITHMUS
aktiv
BFD2_AKTIV
aktiv
BFD2_BFD
blinkend
BFD2_BL
blinkend
BFD2_BL_M
blinkend
BFD2_ESS_ANZEIGE
aktiv
BFD2_ESS_ENABLE
aktiv
BFD2_NSL
blinkend
BFD2_SL_BL_1 (THIS WAS NOT PRESENT IN MY FRM MODULE)
blinkend
BFD2_BLINKEN
5_hz
      06-28-2018, 03:30 PM   #2
codinge90
Drives: e92 M3
Bump
      06-28-2018, 03:36 PM   #3
Cbozz
Cbozz's Avatar
Drives: M3
so this didn't work? don't you have to set algorithm 1 to not active?
Evolve, Eisenmann, Strasse, StopTech, Active Autowerke
      06-28-2018, 03:44 PM   #4
derbo
Derbo Tuning
derbo's Avatar
3610
Drives: BMW M3
some digging found this one. Cbozz good catch on the nicht_aktiv part.
https://www.e90post.com/forums/showp...6&postcount=66
Originally Posted by ******84 View Post
This should work for FRM2, even on US cars:
BFD_1_ALGORITHMUS
nicht_aktiv
BFD2_AKTIV
aktiv
BFD2_BFD
blinkend
BFD2_BL
blinkend
BFD2_BL_M
blinkend
BFD2_ESS_ANZEIGE
aktiv
BFD2_ESS_ENABLE
aktiv
BFD2_NSL
blinkend
BFD2_SL_BL_1
blinkend
BFD2_SL_BL_2
blinkend
WBLG_WBL_ENABLE
aktiv
IG:ruhrohz_m3
Journal: Link
E9x ZCP Suspension Info: Link
SF Bay Area: DM For coding services
Cbozz688.50
      06-28-2018, 03:49 PM   #5
codinge90
Drives: e92 M3
https://www.e90post.com/forums/showp...8;postcount=66
BFD_1_ALGORITHMUS
nicht_aktiv
BFD2_AKTIV
aktiv
BFD2_BFD
blinkend
BFD2_BL
blinkend
BFD2_BL_M
blinkend
BFD2_ESS_ANZEIGE
aktiv
BFD2_ESS_ENABLE
aktiv
BFD2_NSL
blinkend
BFD2_SL_BL_1
blinkend
BFD2_SL_BL_2
blinkend
WBLG_WBL_ENABLE
aktiv
I'll try this. The reason I activated it is because the only thread where it specified frm2 had that enabled. But it doesn't hurt to try that way. I'll report back later today
      06-28-2018, 04:11 PM   #6
Cbozz
Cbozz's Avatar
Drives: M3
LET ME KNOW i was reading about it too and wanted to code that but I have no way to see if it would work lol
      06-28-2018, 04:22 PM   #7
codinge90
Drives: e92 M3
What I did to test is go out at night, windows down and brake hard and you'll see it flash off of trees if it works. It's annoying there's so many threads on brake force display but no one ever gives clear answers lol it's always broken up in like 100 different posts
      06-28-2018, 04:28 PM   #8
Cbozz
Cbozz's Avatar
Drives: M3
yea that's a way to find out! I may try that tomorrow.... let me know how it goes with this...
like you said no one ever gives a clear answer on if this worked...
try it tonight and let me know!!
be the first one to give a clear answer lol
      06-28-2018, 10:53 PM   #9
codinge90
Drives: e92 M3
It works! I had to set BFD_1_ALGORITHMUS to nicht_aktiv. Just copy my notes above and it'll work!
      06-28-2018, 11:00 PM   #10
derbo
Derbo Tuning
derbo's Avatar
3610
Drives: BMW M3
Sweet!
did you have this code enabled as well?
WBLG_WBL_ENABLE aktiv
IG:ruhrohz_m3
Journal: Link
      06-28-2018, 11:19 PM   #11
codinge90
Drives: e92 M3
Sweet!
Yes, I remembered I referenced back to a post and enabled a few more lines than the ones I posted originally in this post. I am going to attach a copy of my TRC file so anyone can reference to it.
      06-29-2018, 12:12 AM   #12
derbo
Derbo Tuning
derbo's Avatar
3610
Drives: BMW M3
Sweet!
If you can, probably should show what you changed as the TRC has a ton of lines of unrelated items.
IG:ruhrohz_m3
Journal: Link
      06-29-2018, 12:26 AM   #13
codinge90
Drives: e92 M3
Sweet!
I'll post the full list tomorrow. It's taken me a few weeks and multiple attempts to get it working so I can't remember off the top of my head but I'll reference back to the other posts and list it all out for everyone.
      06-29-2018, 12:03 PM   #14
Cbozz
Cbozz's Avatar
Drives: M3
you just FA wrote $5AB to FMR only? I thought you suppose to write that in CAS and FRM simultaneously..
      06-29-2018, 01:27 PM   #15
derbo
Derbo Tuning
derbo's Avatar
3610
Drives: BMW M3
There shouldn't need to write the VO if you are manually changing the parameters.
VO alters the set of defaults to enable when you recode the module to default.
My defaults > Required > current values on my FRM3.C32 module.
IG:ruhrohz_m3
Journal: Link
Cbozz688.50
      06-29-2018, 01:35 PM   #16
Cbozz
Cbozz's Avatar
Drives: M3
I was wondering that. If you have all values in your FRM you shouldn't have to add to VO, you're right
I'll try coding and see what happens
      06-29-2018, 01:45 PM   #17
derbo
Derbo Tuning
derbo's Avatar
3610
Drives: BMW M3
What you can do:
Default code your FRM3. Save TRC somewhere.
FA write $5AB to CAS/FRM
Default code your FRM3. Compare to original TRC.
You should be able to see the differences and that will tell you what $5AB defaults are.
IG:ruhrohz_m3
Journal: Link
      06-29-2018, 02:35 PM   #18
codinge90
Drives: e92 M3
Here are the list of changes for FRM2:
BFD_1_ALGORITHMUS
nicht_aktiv
BFD2_AKTIV
aktiv
BFD2_BFD
blinkend
BFD2_BL
blinkend
BFD2_BL_M
blinkend
BFD2_ESS_ANZEIGE
aktiv
BFD2_ESS_ENABLE
aktiv
BFD2_NSL
blinkend
WBLG_WBL_ENABLE
aktiv
CC_MELD_BFD_BEI_DEF_NSL
aktiv
CC_MELDUNG_BFD
aktiv
      06-29-2018, 03:22 PM   #19
derbo
Derbo Tuning
derbo's Avatar
3610
Drives: BMW M3
BFD_1_ALGORITHMUS
nicht_aktiv
BFD2_AKTIV
aktiv
BFD2_BFD
blinkend
BFD2_BL
blinkend
BFD2_BL_M
blinkend
BFD2_ESS_ANZEIGE
aktiv
BFD2_ESS_ENABLE
aktiv
BFD2_NSL
blinkend
WBLG_WBL_ENABLE
aktiv
aktiv
CC_MELDUNG_BFD
aktiv
Thanks!
The last 2 are CC_MELDUNG is Check Control Report in English. They aren't necessary.
IG:ruhrohz_m3
Journal: Link
      06-29-2018, 06:44 PM   #20
Cbozz
Cbozz's Avatar
Drives: M3
BFD_1_ALGORITHMUS
nicht_aktiv
BFD2_AKTIV
aktiv
BFD2_BFD
blinkend
BFD2_BL
blinkend
BFD2_BL_M
blinkend
BFD2_ESS_ANZEIGE
aktiv
BFD2_ESS_ENABLE
aktiv
BFD2_NSL
blinkend
WBLG_WBL_ENABLE
aktiv
aktiv
CC_MELDUNG_BFD
aktiv
Ok I just coded this to my car and you don’t have to code anything to VO no $5AB needed. Just code all above my post here without last two cc_meldung...
It’s working great for NFRM2 and I will post a short video when it uploads in a sec!
      06-29-2018, 07:17 PM   #21
Cbozz
Cbozz's Avatar
Drives: M3
so I wasn't driving fast enough to get a good show but you can see the rear fogs come on and all 3 brake lights started to flash for a split second.
that's without $5AB added to VO
      06-30-2018, 06:11 PM   #22
derbo
Derbo Tuning
derbo's Avatar
3610
Drives: BMW M3
It's a shame its so far, cause I can't tell if it is blinking..
IG:ruhrohz_m3
Journal: Link
