06-29-2010, 02:11 PM | #1 |
Rep 579
PSC vs A048's
I've never tried PSC's but i do have experience with A048's. Does anyone have experience with both? If so, which tire will last longer? I need an r comp i can drive to the track on so i've rulled out the R1 and R6.
06-29-2010, 03:47 PM | #3 |
Rep 7,887
I am RA1's and have driven them a bit on the street with no real problems.I love them as a track tire as they are quite easy to drive on and have good grip throughout their life.
06-30-2010, 03:17 PM | #4 |
Rep 579
I would consider the RA1's... i usually by tires from Tirerack for ease of transaction as the shipping and service is great.
To hold me over until i can decide on a set of track wheels, i purchased a set of AD08's to run on my OEM 18's for Monday's track day at Lime Rock. While i know they won't perform to what i am used to with an r comp, i hope they are a decent compromise. |
07-02-2010, 12:24 PM | #5 | |
Rep 1,680
07-02-2010, 12:41 PM | #6 |
Rep 4,048
Personally the two best tires I've driven on that are street legal and are really meant for track duty, are the A048's (medium compound), and the Toyo R888's which I ran on a Holden Australian V8 on the track.
The Toyo's have unbelievable grip, but I think the Yokos pull it off, it's a great tire that we highly suggest, and especially if you get the medium compound, you'll be loving it as well, but also note that the A048 US Spec medium compound is actually considered Japanese spec Hard compound, but that shouldn't make a difference in your decision. The 888's will go pretty quickly but they don't like a lot of slip angle, that's why I prefer the Yoko A048's, mainly because I like a little slip angle (maybe more than others), mid-corner to exit. The 888's also, if you've got a lot of understeer in the car, will absolutely melt if you push them too hard, so be aware of that, this is mainly because they do not handle the heat very well. So essentially, the Yokohamas wont be the fastest tire on the road, but they last and last. If you want a short burst of a great tire, the R888's are good, but if you push them too hard, you'll just go off. Hopefully that bit of info helps out |
07-02-2010, 12:58 PM | #7 | |
Rep 7,887
07-02-2010, 01:13 PM | #8 | |
Rep 4,048
Once I did use them on the same car in the dry, pushing about 625HP (approx), yeah they go EXTREMELY quick. My rears in the dry were done in about 2 hours or so from being in the wet, then moving to the dry once th track cleared up. |
