11-12-2010, 09:43 PM | #1 |
Rep 480
How Do You Plug an MP3 Player Into Audio System?
dumb question i know, but i'm struggling to figure this one out. i have a zune mp3 player with a ton of subscription music on it, and i want to be able to play it through the car audio system. as far as i can tell the oem ipod/usb cable won't work, and i've tried to plug the zune in via the zune/usb cable. that doesn't work either. what i'm left with is buying a 3.5 to 3.5 cable to run from the headphone out on the player to the aux in on the car, or possibly a 3.5 to usb to do the same thing. will this work, and am i thinking of this the right way? i know apple owns the world but i would have preferred to get a set of cables that allows you to plug in any old mp3 player, not just an apple product. anyway, thanks!
11-12-2010, 10:26 PM | #2 |
Rep 6,845
Drives: 2018 Audi RS5 coupe
Only way is aux input Jack
Is there a line out on zune? Or is it just headphone? |
11-12-2010, 10:33 PM | #3 |
Rep 480
zune only has the proprietary input (looks like the ipod connector but of course is not compatible) and the headphone out. so i'm thinking i need a headphone (3.5mm) to aux (also 3.5mm) cable. just out of curiousity are you saying i can't get a 3.5mm to usb cable instead? i buy all my cables at monoprice so they only cost a few bux each so no biggie if i have an extra..thanks.
11-12-2010, 10:34 PM | #4 | |
Rep 13,011
11-13-2010, 07:24 AM | #5 | |
Rep 6,845
usually the quality of audio at the line out port is higher than the headphones as its not run through the internal amplifier http://cgi.ebay.com/Zune-MP3-Player-...item3f04306f31 |
11-13-2010, 07:25 AM | #6 |
Rep 6,845
or this so you can use a longer cable
http://cgi.ebay.com/Zune-MP3-Player-...item4153c06474 |
11-13-2010, 08:14 AM | #7 |
Rep 480
i'm wondering if the problem using the zune cable is that the music on the device is subscription, so the audio system might not play it. if i just use the 3.5mm headphone out, it should be able to just take the signal i would hope...thanks!
