12-23-2014, 02:05 PM | #1 |
Rep 8
17 wheel help
Swapping my 19s for some 17x10 et 25. Want to run 275/40r 17. Wondering if these will fit all around and if the 17s will allow for a BBK down the road.. Any help is appreciated.. I have 08 m3 coupe
12-23-2014, 04:10 PM | #2 | |
The Dr
71
Rep 169
I always remember these photos: I will be doing this exact setup, but with RA1s, next year.
2013 M5 - Manual "You gotta fix the nut behind the wheel before you fix the bolts on the car" |
12-23-2014, 06:04 PM | #3 |
Rep 1,470
You can run ST40 at all 4 corners but not ST60 up front if you go to 17's.
12-23-2014, 08:13 PM | #4 |
Rep 8,075
Drives: 11 E90 M3 Individual
I run a similar setup. Apex ARC8 17x9.5 et35 and a 12mm spacer. Clears a Stoptech ST40/355mm BBK.
2018 F30 320iX Melbourne Red
12-24-2014, 12:44 AM | #5 |
Rep 328
i run 17x10.5 275 40 square, fits fine. abit of rubbing on the suspension on the front even with a 5mm spacer. Maybe 10 inch will be fine.
the stock brakes barely clear the barrel. I think the only possible bbk upgrade would be the stoptech or the essex 355 kit. |
12-27-2014, 10:15 AM | #7 |
Rep 8,075
You can find more street tires with an 18" rim which means nothing for a track setup.
Extra weight in the car from the cash that you save. I guess the ride will be a tad softer with 17s but it felt the same to me.
