02-24-2017, 08:53 AM | #1 |
Rep 409
AC Belt: what is correct part number?
EPC lists 2 part numbers for the AC belt and they are 1" different in length. One is 11287841529 and the other is 11287841529. Which is correct?
EPC: http://www.realoem.com/bmw/enUS/show...20#11287838200
Jon Maddux
coupenut.blogspot.com x5nut.blogspot.com 16 X5d | 08 M3 Sedan | 06 M Coupe | 01 M coupe | 99 M coupe |
02-26-2017, 08:11 AM | #2 |
Rep 2,907
Drives: 2011 E93 M3
It has to do with your production date. Some of the earliest 2008 M3's have power steering pumps that rotate in an opposite direction than later builds. The early style PS belt is slightly smaller and runs over the top of the PS pulley and is ribbed only on one side. Later builds the belt is slightly larger and runs under the pulley- this belt is ribbed on both sides.
Early style: If your AC belt goes over the PS pulley use belt 11287838200. Late style: If your AC belt goes under the PS pullet use belt 11287841529. |
JonM144.50 |
02-26-2017, 09:11 AM | #3 |
Rep 409
deansbimmer, EXCELLENT info, many thanks. Would have been easier if EPC listed the cutoff dates. My 5/08 build is the later double-ribbed style.
Jon Maddux
02-26-2017, 05:21 PM | #4 | |
Rep 2,907
Drives: 2011 E93 M3
In my experience they don't list "stop" dates for superseded parts unless the part is no longer manufactured or available which isn't the case with this part. |
