12-13-2009, 03:10 PM | #1 |
Rep 47
Cold Weather Effects?
I live in Atlanta and the weather recently starting getting a bit cooler, mid 30's or so at night. Took the M out the other night for an early Christmas party and she was parked outside for maybe 2 hours.
When I came out and started the car, I received several immediate errors...most importantly the tire pressure had changed in the front right tire. I also received a message about the bluetooth not being able to pair and the cold weather message. Could the cold weather cause the tire pressure error? I reset it and it has not come back on.... Any advice about other cold weather experiences would be appreciated. My car is garaged otherwise and this is really the first cold weather it has experienced. Thanks |
12-13-2009, 03:36 PM | #2 |
Veni Vidi Vici
89
Rep 2,750
Drives: '11 JB/BBe-6sp-e90
Garage List 2011 e90 M3-Sold [8.50]
2003 RS6 - Sold [0.00] 2009 e90 M3 - Gone [0.00] 2003 M3 SOLD [0.00] old 2002 [10.00] |
Check your tire pressures as the weather gets colder.
Other than that, there are no issues with the car that are temperature based. Try leaving any car outside in -20 degree weather, then start asking questions about why the doors don't close the same or why the engine is in limp mode. All sorts of weird a$$ $hit used to happen to my RS6 when I had it in Minnesota. |
12-13-2009, 05:17 PM | #3 |
Rep 1,887
Drives: '20 M5C, '09 M3 DCT Coupe
What was your tire pressure before the weather got cool? If it was right at 32 or 33 psi and then the temps drop a little, that's all it would take to trigger the tire pressure warning. Tire pressure should be checked on a regular basis. Bluetooth shouldn't have anything to do with temp... shit happens and that was most likely just a coincidence. Temp warning happens at 37 degrees and is normal, not an error message.
12-13-2009, 05:22 PM | #4 | |
Naval Aviator
575
Rep 665
As previously noted, one must be aware and pay attention to the tire pressure changes with low temps, but the TMPS system does work well if mindful. Remember, BMW originates from Bavaria where winters are in fact cold, so it's designed with adequate capability, especially compared to ATL winters .
e92 M3 - Interlagos Blue | Fox Red Extended |Carbon Leather
Performance Mods: Alpine Stage II E85; SuperSprint F1s; Cat-less Bomiz X-Pipe; aFe CAI; Bilstein B16s w/EDC; Brembo BBK; AutoSolutions SSK |
12-13-2009, 06:12 PM | #5 |
Rep 1,887
You should also be aware that your tires are considered high performance summer tires... the compound starts getting pretty hard under 40 degrees so don't expect the same grip you are used to at higher temps. Other than that, it's a car like any other and you'll never see temps in Atlanta that should be a problem for any car, let alone one designed for and by Germans. Mid 30's would be considered a heat wave by a lot of us.
12-13-2009, 06:34 PM | #6 | |
Naval Aviator
575
Rep 665
Believe me they'll work year-round, that's what I use for MN winters.
12-13-2009, 07:22 PM | #7 |
Rep 296
The cold weather warning is normal, I believe it does that when it's below 37 degrees.
I had a similar problem with mine and a "TPM Malfunction" error. They first night I left it parked out when the temps were below 30 (I was working late) I got the "TPM Malfuction" when I started the car, and it kept beeping every 20sec (literally!). I went to the closest gas station and check the pressure, all the tires were at 30psi, so I filled them up since the fronts should be 32psi, and the rears 35psi and I reset the TPM. It still did it all the way home, where I parked it in the garage. When I left the next day it was fine. Then that next night I had to work late again and the same thing happened when I left "TPM Malfunction" every 20sec, beep, beep, beep. I checked the tires again but they were the same lvls from when I filled them the night before. I haven't driven the car since then because it has snowed now, but I was starting to think it has to be related to the compound of those tires and it being so cold (20's), but curious what the "experts" say about that.
SOLD - 08 E92 ///M3 (bought a house)
NEW - 99 E36 ///M3 Convertible |
12-13-2009, 11:23 PM | #8 | |
Rep 1,887
12-13-2009, 11:28 PM | #9 | |
I Drive Slow To Save Gas :D
26
Rep 464
12-13-2009, 11:34 PM | #10 | |
Rep 296
But see it's not a TPM warning. I have seen a warning once when one tire got way lower than the others, and it actually said something like "hey the passenger rear tire is low", but this issue says on the iDrive "TPM Malfunction!". Also the TPM doesn't know the psi of any the tires, it just can tell if there is difference in pressure of one tire compared to the others. If they all go down equally it won't say a thing to you. Which is why they tell you to still check the tire pressure regularly, despite having a TPM system.
12-13-2009, 11:48 PM | #11 |
Rep 1,887
Well, tpm warning comes in at 31. That's been the case for this and my previous 2 cars. If you want to keep your tires at 32, be my guest, but expect tpm warnings as air slowly bleeds away and, as lots of people are finding out this time of year, when it gets colder. I'm just passing on what I've learned from experience. 32 is the minimum, so, as should be the case, if the pressure goes below the minimum, you get a warning. Just common sense to stay above the minimum, not at the minimum. Technically, it's ok to run oil level right at the minimum all the time, but is it a good idea? No.
12-13-2009, 11:55 PM | #12 | |
Rep 1,887
12-14-2009, 12:02 AM | #13 |
Rep 2,148
I had the low tire pressure warning go on this week. Monday was the left tire and Thursday on the right tire. Filled it up to 33 psi and it went away each time.
I keep on getting the "left daytime running lights/ brake lamp malfunction" error msg. every time the temps went below 37 degrees. My friends think I'm losing my mind when I repeatedly ask them to help me check my lights. Anyone else get this error message? It gets pretty damn annoying!
12-14-2009, 09:25 AM | #14 | |
Naval Aviator
575
Rep 665
for more info...
12-14-2009, 09:40 AM | #15 |
Rep 2,148
Really? I can't seem to find it.
12-14-2009, 01:33 PM | #17 |
Rep 959
I had a DSC error message as well as a reduced power message the first day it got below 30 here in Massachusetts. Later that same day my nav screen went pink and then stopped working. All the problems went away after a restart and I have not had any problems since then.
12-14-2009, 02:24 PM | #18 |
Rep 4,145
Bluetooth should definitely work in the cold. That's what it was designed for. After all, they don't call it bluetooth for nothing.
Seriously, fill up the tires with a bit more air then wait and see if the problems persist. Germans love their technology and this car is full of it. Little gremlins will show up every now and then. If they persist, or if you think it's a dangerous situation then take it in to your SA. I wish I could offer more encouragement, but I wouldn't worry about it too much.
2017 F80 YMB.
12-20-2010, 01:30 PM | #19 |
Rep 8,496
wow no kidding about tire pressure losses, I went away on vacation for 2.5 weeks and everyday it was around freezing.
when I got back, the right front tire was down to 25 psi! I just filled it again, I'll check to make sure I don't have a nail too. It's unbelievable it'll drop that low in 2.5 weeks. The car is in the garage too. |
12-21-2010, 01:40 AM | #20 | |
Rep 5,012
Talking about bluetooth, got that error the other day, and it wasn't even close to freezing. But phone worked fine, so guess it was just if you wanted to pair another. Have gotten quite a bit of weird warnings and gremlins since new, but never more than once. Hope it stays that way with the bluetooth as well. Good luck. |
12-21-2010, 04:08 AM | #21 | |
Havin' a blast!
123
Rep 4,847
BRP 1:56 | CVR 2:01 | ACS 1:53 | WSIR 1:34
12-21-2010, 07:52 AM | #22 |
Rep 803
If they were at 32, that sounds like more than temp fluctation. Like an actual slow leak.
Also, doesn't the TPMS register changes from the values once you reset it, as opposed to differential values amongst the tires?
Objects in mirror are slower than they appear.
