01-05-2015, 12:43 PM | #1 |
Grown Azz Man
430
Rep 3,021
Swift Spec R Springs Installed
Well the deed is done and I'm thrilled with the results. The springs are finally on. The photos are one day after the install. The springs haven't settled yet but the drop in the front is already 3/4 of a inch. Once they're settled I should see a full inch. The alignment was done without removing the pins. No rubbing issues noted. See Specs below............Phil
275-30-19 PSS 19x9.5 et.35 Dinan Spec CH-R's Camber -1.8
2016 GT4.....Sapphire Blue Metallic, Platinum stitch Leather/Alcantara interior, Carbon Fiber Trim, PCM w/Nav, Guards Red Belts, 2 Zone Climate, Sport Chrono, LWB, Smokers Pack, Big Gas Tank, Light Design Pack, Bi-Xenon w/PDL, Auto Dim Mirror, Clear Side Markers, GTS Clear Taillights
01-05-2015, 09:54 PM | #2 |
Grown Azz Man
430
Rep 3,021
Update on Ride Quality.....Had time to take a drive with the CEO in the car and all seemed well. The ride quality seems to be on par with the factory springs. Although I will say you can tell something is different. I'll have a better feel for them next weekend at the track. Also, as others have noted, body roll has diminished some.......not sure how Swift has been able to do this. So far, so good ..............Phil
01-06-2015, 04:13 AM | #6 | |
Rep 2,665
Drives: Goggomobil
F86 X6///
01-06-2015, 07:32 AM | #7 | |
Rep 12,316
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT 08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT 07 E85 Z4M Roadster, Alpine White/Red, 6MT 99 E36 M3, Techno Violet/Dove Grey, 6MT |
01-06-2015, 08:50 AM | #8 |
Rep 1,530
Drives: '11 BMW M3
Looks great, not sure I've read a single post on here where a user was not happy with their Swift springs.
New: '11.5 e90 M3 | DCT | Space Gray/Novillo | ZCV | ZCW | ZP2 | ESS 625 | BPM | M Performance | iPE | BC Racing | BPM | iND | LUX | Volk | Coby | Recaro
Sold: '11.5 e92 M3 | DCT | Mineral White/Novillo | ZCP | ZCV | ZCW | ZP2 | M Performance | ACM | BPM | iND | Thule | LUX | Macht Schnell | Broadway Static | Rogue Engineering | BBS | Challenge | Metak |
01-06-2015, 09:48 AM | #9 | |
Currently Driving
269
Rep 1,426
Drives: BPM tuned '13 AW ZCP E92 M3
01-06-2015, 11:36 AM | #10 |
Rep 6,696
Drives: F30 340i
01-06-2015, 08:56 PM | #11 | ||
Grown Azz Man
430
Rep 3,021
Thanks for the luv fellas............Phil
Right now there's less than a inch getting in my driveway. After my track day next weekend (springs will settle by then) I'll measure from the ground and give you a number. Quote:
I do indeed have EDC and as stated by W///, it's almost like another setting has been added.
01-06-2015, 10:04 PM | #12 |
Currently Driving
269
Rep 1,426
Very cool. I've been looking for a nice set of springs, as I love the stock ZCP suspension, just want it a tad lower. Did you install the so-called e36 bump stops? Or just installed the springs , did alignment and off you go? Simple as that? Really diggin this setup for mine if i can get away with doing just springs and alignment. Not looking to spend crazy money on a KW suspension and change everything I love about the stock ZCP EDC.
01-07-2015, 03:48 PM | #13 |
Rep 923
How many miles do you have on the edc shocks? Was thinking going back to edc with swifts, but i have 60k+ miles on them and replacement shocks are $$$$
01-07-2015, 08:15 PM | #14 | |
Grown Azz Man
430
Rep 3,021
Just a tad over 50k on the shocks. You should be fine at 60k.........Phil
01-08-2015, 05:22 PM | #15 |
Rep 12,316
I've got 83k miles on my car now. I think I installed them at 70k something, perfectly fine.
Current:
01-08-2015, 07:25 PM | #16 |
Rep 923
01-08-2015, 07:42 PM | #17 |
Watch This!
33
Rep 705
That looks awesome! I was wondering how a 275 with that ET rim would look. Only problem now is finding out if a 19x11 with a 295 and ET 25 play nice with that kind of drop.
01-08-2015, 09:06 PM | #18 |
Rep 893
they play nice, until you go over a huge dip at high speed with more than 2 people in the car... not that I would know...
01-09-2015, 08:12 AM | #19 | |
Rep 12,316
Current:
01-09-2015, 02:16 PM | #21 | |
Rep 12,316
The front is currently stock size, but that's just the way they came with the wheels. I'm planning on going 275/30/19, and the wheel specs are 19x9.5 ET22 (again not sure 100% about offset)
Current:
01-16-2015, 01:48 PM | #22 |
Grown Azz Man
430
Rep 3,021
Ok gang, there are a couple of question I need to answer. So the measurement from the ground to the fender is now 25 inches on all 4 corners. So anyone that was concerned about a "hot rod" rake need not worry. And my lip is exactly 5 inches off the ground. These measurements are with no one in the car. The springs have settled nicely.........Phil
