09-27-2011, 12:50 AM | #1 |
Supreme Allied Commander
3834
Rep 54,333
Drives: F80 M3
Location: Santa Barbara, AP, Brembo, GIAC, Koni, Ohlins, Performance Friction, www.hpautosport.com
Race Car Engineer Carroll Smith's take on brake fluid
Carroll Smith, a respected and winning professional racer, team manager and race car engineer. If you have not read some of his books(e.g., Tune To Win and Engineer To Win), read them.
Here is what he had to say with regards to brake fluid: Carroll Smith's Notes on Brake Fluid Brake fluid is possibly the single most neglected component of the automobile. Most high performance drivers check their tire pressures and change their engine oil at frequent intervals. Virtually no one (including me) ever changes the brake fluid in their street car - or even bleeds the brakes. WRONG! The function of brake fluid is to provide an incompressible medium to transmit the driver’s foot pressure on the brake pedal through the master cylinder(s) to the calipers in order to clamp the friction material against the discs. The foot pressure is multiplied by the mechanical pedal ratio and the hydraulic ratio of the master cylinders, booster (if used) and caliper piston(s). This is a simple concept. When fresh, all brake fluids are virtually incompressible and the system works as well as its mechanical and hydraulic design allows. There are, however significant problems. Overheated brake fluid can (and will) boil in the caliper. Boiling produces gas bubbles within any boiling fluid. Gas is compressible so boiling brake fluid leads to a “soft” brake pedal with long travel. In extreme cases overheated brake fluid necessitates “pumping the brake pedal” in order to get a pedal at all. There are five possible solutions to the boiling fluid problem: 1. Don’t use the brakes so hard 2. Provide (copious) cooling air to the brakes 3. Install Titanium or Ceramic caliper pistons. Alternately install 2-piece pistons made from aluminum with a noise piece of Titanium or Ceramic. (Note that aluminum pistons are used as opposed to stainless steel to match the expansion rate of the piston to that of the caliper body to ensure the piston seal condition and preload is optimal through out the temperature range.) 4. Install Titanium pad backing plate if they are available for your caliper. 5. Change to a brake fluid with a higher boiling point. The first is unacceptable. The second is expensive. The third is really expensive in its various forms. The fourth is relatively cheap. The fifth is easy and relatively cheap. For most of us easing up on the brake usage is not an option and increasing cooling air to the system is filed under too difficult so we upgrade the fluid. Some of the reputable racing fluids include: · AP 550 · AP 600 · ATE Super Blue Racing · ATE TYP 200 · ELF HTX 115 · Motul 550 · Motul 600 · Neo 610 · Performance Friction Z rated Finally, Castrol SRF is a racing brake fluid that is in a class by itself with patented chemistry and is, in my opinion, the best racing brake fluid on the market today. This leads to a discussion of boiling points. Brake fluids are classified by both “dry boiling point” and “wet boiling point”. They are also classified by US Department of Transportation (DOT) rating, DOT 3, DOT 4, DOT 5, and DOT 5.1. As we would expect the dry boiling point is just that - the temperature at which a given brake fluid boil when it is fresh out of the can. This is the rating by which most high performance drivers and all racers select their brake fluid – from the standard racing 550 degrees Fahrenheit to the 600+ degrees Fahrenheit offered by the extreme use fluids. As a point of interest, even though they may have the same DOT rating, racing fluids are less compressible than street fluids, especially after they have been overheated. For high performance street car use, the wet boiling point is at least as important as the dry. DOT 3 DOT 4, and DOT 5.1 brake fluids are ether based and, as such they are hygroscopic in nature - i.e. they adsorb water at every opportunity. Since water boils at 212 degrees Fahrenheit (100 degrees Celsius) the adsorbed water dramatically lowers the boiling point of the brake fluid. A minute amount of water suspended in the fluid decreases the boiling point as much as 1/3. Damn! The fluid in the system absorbs water through the breathers, through the caliper piston seals and by magic. Not only does this reduce the boiling point, the entrained water leads to corrosion of both ferrous and Aluminum internal parts. Double Damn!! So buy your brake fluid in small containers and don’t save the leftovers. I use Ford C6AZ-19542 which was developed in the early 1960’s to cure the problem caused by Lincoln Continental drivers boiling the fluid by habitually resting their left feet on the brake pedal. It is inexpensive and it works just fine. But upgrading the fluid is not the whole answer. Unfortunately the hygroscopic nature of the ether based fluids means that they should be completely replaced at scheduled time based intervals (annually would be good) and that the system should be bled to replace the fluid in the calipers every time that it is overheated to the point of generating a soft pedal. Yes, the pedal will come back as soon as the fluid cools somewhat - but the boiling point is now reduced and the pedal will go mushy at a lower temperature the next time. Triple Damn!!! Fortunately, changing to a 550 degree Fahrenheit fluid and replacing it annually will solve the problem for all but the most heavy footed among us. Ah ha, you say - but what about the much touted Silicone based brake fluids? They are non hygroscopic and should take care of the reduced boiling point and corrosion problems. True! That’s the good news. That is why they are specified by the U.S. Military. Unfortunately the silicone based fluids are compressible themselves so they produce a soft pedal all by themselves. For the person who doesn’t care about a spongy pedal or precise modulation silicone fluids may well be the answer - but not for anyone reading this. In fact, low compressibility is a desired characteristic in a high performance brake system – lower compressibility results in more linear force output for driver input and improved driver feedback. So, you say, “I’ll just run my hot rod down to my dealership or mechanic and ask them to replace the fluid with AP 550.” Two problems here. First of all they won’t have it and won’t know where to get it. Second and more serious (after all you could supply it yourself) all dealerships and most independent mechanics use pressure bleeders. These devices certainly speed up the process of brake bleeding, but by forcing the fluid through tiny orifices using pressurized air, any air left in the partially filled system will be forced into the fluid solution. Quadruple Damn!!!! If you are either racing or doing lapping days, the brake fluid should be replaced both before and after each event. A cool off lap before each stop will go a long way toward preventing fluid boil due to heat soaking after the airflow stops when the car does. |
09-27-2011, 06:14 AM | #2 |
E46 + E90 + F80
192
Rep 2,894
Drives: E46 + E90 + F80
Good read!
I'm currently using Motul RBF600 and am pretty content with it. Granted I am no where near the fastest driver out there, but it has been holding up well. I only amazing things about Castrol SRF, but man is it pricey haha. Thanks for sharing Harold!
F80 M3 DCT|Alpine White . Black Leather | My Build Thread
E90 M3 DCT|Melbourne Red . Speed Cloth | My Build Thread E46 M3 6MT|Jet Black . Black Nappa Leather | My Build Thread |
09-27-2011, 07:17 AM | #3 |
Rep 7,888
You do realize that Carrol Smith as been dead for 8 years?I still read his stuff but a lot of it is outdated by newer technologies coming out to the market.I am not saying this is the case for brake fluids but something to be aware of.
09-27-2011, 09:25 AM | #6 |
1122
Rep 7,690
I have tried most of the brake fluids out there and most of them didnt do it for me so i switched to SRF a couple of years back and got no regrets. you just have to flush it once a year.
09-27-2011, 09:48 AM | #7 |
11817
Rep 23,187
Good read. I'm geting step 2 and 5 done soon. Copious cooling to the backing plate and high temp fluids.
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs| |
09-27-2011, 10:19 AM | #8 |
3834
Rep 54,333
Drives: F80 M3
It may be common sense to some of you, but have a look at the other forums and you will realize how little people know about brake hydraulic systems.
09-27-2011, 11:19 PM | #9 |
Rep 9,032
And yet, you still use Motul.
09-28-2011, 08:14 AM | #10 |
Rep 134
Thanks Harold! Got my rear pads yesterday from you and am putting them on today. Track day is tomorrow. Hopefully they hold up, but either way I'm quite sure I'll be ordering a Trophy Kit from you by next Spring. Any word on the Ford GT?
09-28-2011, 10:19 AM | #11 |
11817
Rep 23,187
I'm with vivek on this one. I priced out motul 600 and castrol SRF yesterday for a complete flush. 6 pints of motul 600 is 105 and for the SRF its 222 from turner. The price difference allows you to do a complete fluid change twice as often and to me seems to be the better value.
09-28-2011, 10:50 AM | #12 | |
3834
Rep 54,333
Drives: F80 M3
There is two kep advantages with SRF that you don't get with any other conventional fluid: "The silicon ester technology in Castrol SRF addresses this problem in two ways. Firstly, Castrol SRF is less hygroscopic than conventional brake fluids - it absorbs less water in a given time. Secondly, unlike conventional glycol ether fluids, Castrol SRF reacts chemically with the absorbed water to reduce its adverse effects, thus preventing the fluid's high temperature performance and safety margins from deteriorating as rapidly as they would otherwise do." As soon as brake fluid bottle is opened the process starts and can greatly affect its performance and it only gets worse overtime. The SRF fluid combats that much better. And carries a wet boiling temp of 518F, almost a 100F higher than Motul 600. |
09-28-2011, 11:55 AM | #13 |
11817
Rep 23,187
okay what i dont get is why you need to completely flush before each track event. i dont need to do that with stock fluid? my pedal gets a little soft but why would a way higher performace fluid need more maintenance?
09-29-2011, 01:18 AM | #14 |
Rep 9,032
Great post here: http://www.m3post.com/forums/showpos...11&postcount=7
More info here: http://forums.bimmerforums.com/forum...&highlight=srf You have to decide if it's worth the money and time to have to flush the brakes one extra time a year. And our stock fluid SUCKS BALLS. 446 dry/311 wet per LeMans_Blue back in the day. . |
09-29-2011, 10:11 AM | #15 |
11817
Rep 23,187
Wait. How much volume is needed for a full flush? I asked my service advisor the other day and was told 6 pints, which seemed like a lot. Is it only 1 liter so 2 pints? If that is the case I get why srf is better. I thought each flush was 225 for just the fluid.
09-29-2011, 11:45 AM | #17 |
3834
Rep 54,333
Drives: F80 M3
One liter is all you need.
09-29-2011, 06:21 PM | #18 |
11817
Rep 23,187
well why the hell did my sa tell me 6 pints i would have shown up to have it done with 225$ worth of srf and been pissed.
09-29-2011, 08:08 PM | #19 |
3834
Rep 54,333
Drives: F80 M3
09-29-2011, 08:43 PM | #20 |
11817
Rep 23,187
thanks for the help just ordered some srf. im convinced now. also got a stud conversion kit from turner while i was at it.
09-29-2011, 11:45 PM | #21 |
Rep 9,032
Did you get the expensive studs from Turner? Those are the one's you want. I think they sell them individually.
09-30-2011, 12:53 AM | #22 |
11817
Rep 23,187
yes they are sold individually for 6.96 a piece i think and the lugs are 2.25.
