BPM
      11-05-2017, 02:31 PM   #1
Merlin_83
Merlin
Merlin_83's Avatar
Drives: 2012 BMW M3 w/ZCP 6MT
Question Rarely get flashed to change from Hi-Beams -why?
Greetings,
I have three lightning questions;
Ok this is likely a dumb question but I've noticed that I almost never get flashed with dual Bi-Xenon (Lo and Hi) lights on. Is there some kind of auto dimming feature or motor driven feature to move lights slightly away from oncoming traffic by means of an opto sensor of sorts ?
I've seen where it's possible to code into the DME and ask that the halo lights are driven to near 100% or full bright - I think those are incandescent type and would that produce much higher heat ?
Do the aftermarket LED halo replacements last long ? I've heard of mixed reviews about them lasting for a few years vs. OEM (standard incandescent) lasting 6++ years, is this true ?
Thank you,
Merlin
2012 BMW M3|ZCP|6MT|Navi|Cold Weather Package |Premium Package|
      11-05-2017, 02:33 PM   #2
dparm
But doctor...I am Pagliacci.
dparm's Avatar
Drives: Corvette Grand Sport
Originally Posted by Merlin_83 View Post
Greetings,
Thank you,
Merlin
Auto high-beams were an option on the car. Check your build sheet and see if you have them.
I would not run the halos brighter; as you said, you risk damaging the housings or wiring. Have you ever priced out replacements? Pretty expensive. It would also look pretty obnoxious.
The LED aftermarket halos seem to be hit or miss. I see a lot of people complaining on here about how they flicker or go out. Even though they're warrantied, that's a real hassle to keep replacing them all the time. For what it's worth, my OEM halos were 6 years old when I sold the car and still on the original bulbs. They're not running with much power so they'll last for a long time.
Now: 2017 Corvette Grand Sport
Past: 2011.5 M3 sedan ZCP
      11-06-2017, 03:22 PM   #3
DSilk
Drives: 2008 BMW M3 Coupe
If you don't have automatic dimmers, the reason might be that many pople aren't sure whether they are looking into high beams or low beams, since the HID lowbeams are substantially brighter than standard halogens, and both low beam and high beam lights are in the same housing. Unlike most cars with 4 headlights, the inner pair are not the high beams. Indeed, the second set of headlights (the inner pair) only illuminate when the steering wheel is turned or the turn signals are on (since the main beams are directional, and shift with the steering).
      11-06-2017, 03:44 PM   #4
Z K
Z K's Avatar
Drives: E90 M3, B8.5 A4
I'm, sure they don't like it but probably don't know if you just have really bright low beams or misaligned headlights.
The "high" beam is just the low beam hid with the shades moved up so it goes higher. The high and low are the same projector.
Auto Detailing Enthusiast!
      11-06-2017, 03:45 PM   #5
R3dliner
R3dliner's Avatar
Drives: 2011.75 E92 M3 6MT
Halos brightness is non adjustable
      11-06-2017, 04:12 PM   #6
roastbeef
roastbeef's Avatar
Maybe nobody is flashing you because everything is working correctly?
      11-06-2017, 06:15 PM   #7
3Pedals_6Speeds
Drives: E93 M3
If you don't know if you have auto dimming, why aren't you dimming as cars approach?
Former: E21, E63, Current: F10, E93 M3. Drive fast, take chances.
      11-06-2017, 06:33 PM   #8
UPSROD
Drives: 2013 E92 M3
2013 BMW M3  [5.00]
Greetings,
Thank you,
Merlin
Run your VIN # and see if you have S5ACA.
      11-06-2017, 07:08 PM   #9
inTgr8r
inTgr8r's Avatar
Drives: E86 Z4MC; E92 M3
      11-06-2017, 07:22 PM   #10
monterey
monterey's Avatar
103
Drives: 2008 M3
They can be adjusted with the Carly ap.
A job is nothing but work.
      11-07-2017, 10:12 AM   #11
R3dliner
R3dliner's Avatar
doesn't work on mines with carly. I've tried every dim setting.
      11-09-2017, 03:54 AM   #12
thkfast
thkfast's Avatar
101
Drives: 2013 E92 M3 Mineral White DCT
I'm surprised you aren't getting flashed with your high beams on. I do usually end up adjusting my headlights UP a few notches from the factory setting so I can see what's ahead of me at highway speeds. Maybe your headlights are adjusted LOW. The only way you'll know what others are seeing is to have someone else drive your car at you with the HIGH BEAMS on!
"The likelihood of one individual being right increases in direct proportion to the intensity with which others attempt to prove him wrong."
2013 E92 M3 - Mineral White Metallic / Tan Interior / OEM 2.5 exhaust mod / CF bits and pieces
Search this Thread:
Advanced Search
