09-12-2013, 09:41 PM | #1 |
Rep 818
I just got my car back from an oil change a couple of days ago. While I was cleaning the engine compartment up a little yesterday I noticed (or never noticed before) that I can see straight through the engine to the ground in a couple areas.
I have a couple pics where you can see the light shining through at the bottom. Am I just paranoid or did the dealer forget to put a panel back on? |
09-12-2013, 10:58 PM | #3 | |
Rep 818
09-12-2013, 11:11 PM | #5 |
11817
Rep 23,187
I don't have my e90 so can't go look for you but I would say yes. There is the felt undertray as well as another panel in the center that runs back to around the wheel area if I remember correctly. You shouldn't be able to see the ground.
09-12-2013, 11:34 PM | #6 | |
Rep 818
09-12-2013, 11:49 PM | #7 |
11817
Rep 23,187
no the oil drain plugs are exposed and no panels should need to be removed.
09-13-2013, 10:51 AM | #8 |
Rep 818
09-13-2013, 11:42 AM | #9 |
Rep 207
Yes you are just paranoid. You are supposed to see through in a couple small spots, exactly where you have photographed, my car is the exact same and there are definitely no panels missing.
2013 E92 M3 / Phoenix Yellow / Fox Red Extended / 6MT
2006 E46 M3 / Phoenix Yellow / Black Nappa / 6MT www.EMKEL.com |
09-13-2013, 01:47 PM | #10 |
Rep 2,792
The dealership didn't remove any panels to do your oil change so either they were already missing or you are paranoid.
2008 IB E92 M3| BBS | KW | Arkym | Platte Forme A.G. | Active Autowerke | K&N | Fabspeed | Dinan | Evolve-R |
09-13-2013, 07:31 PM | #12 |
Rep 358
