04-02-2022, 07:51 PM | #1 |
Rep 8
Need help! Front left camber stuck at -2, OEM suspension
Hi guys, I reinstall the stock suspension (2011 zcp edc) yesterday. And after two alignments, my front left wheel has a negative camber at -2, and my front right wheel was perfectly fine.
My front caster and toa are all in the right spec (OEM spec), I attached a photo of the alignment results. Does that mean I have a bent suspension component? BTW I had both alignment shops try to adjust the camber using the top pins. they successfully managed to increase the front right camper from -1.2 to -1.4. But the front left suspension won't change, just stuck at -2 degrees. Does anyone have the same issue with OEM suspension? |
04-02-2022, 10:56 PM | #3 | |
Rep 8
once you put back coilovers then the problem is fixed? Which coilover you have? |
04-06-2022, 11:31 AM | #5 |
Rep 64
