      04-05-2017, 05:45 PM   #1
OM VT3
OM VT3's Avatar
140
Drives: 2011 e92 zcp m3
Rear strut Tower reinforcement
Does anyone know if someone sells plates to weld into the rear strut Tower to reinforce them for a coilover conversion?
      04-05-2017, 07:43 PM   #2
Redd
Don't think it's necessary. My friend uses Nitron coilovers in the rear for his track M3 and never had any problems.
      04-05-2017, 09:26 PM   #3
OM VT3
OM VT3's Avatar
140
Do you know what spring rates he went with?
      04-05-2017, 10:06 PM   #4
roastbeef
roastbeef's Avatar
It is recommended.
      04-05-2017, 10:20 PM   #5
OM VT3
OM VT3's Avatar
140
It is recommended.
Not by nitron for street and a little bit if track
      04-06-2017, 02:20 AM   #6
Redd
Nope, sorry.
      03-23-2022, 02:18 PM   #7
alpine2530
Sorry to bring this thread back from the dead. I’m currently looking at converting to true rear coilovers. Nitrons claims that it isn’t needed and plenty of their customers run true rear coilovers without any issues. However, guys at Intrax recommended to reinforce the shock towers to run this setup but they also mentioned that they have customers running this setup without any issues as well.
I’ve been spending days looking up online but there isn’t much surrounding the subject. Has anybody reinforced their shock towers for our cars without welded roll cages? Or is anybody in here that tracks their cars run true rear coilovers without any reinforcements? Any issues?
Thanks,
Don
      03-23-2022, 03:01 PM   #8
roastbeef
roastbeef's Avatar
It doesn't seem to be a big concern for most applications. I used to think it was necessary, but I'm currently running true rear coils without reinforcement without issue.
      03-25-2022, 01:56 AM   #9
alpine2530
That’s good to know. Couple of questions if you don’t mind. Do you track your car? What’s the benefit of running true coilovers in the rear as opposed to a divorced setup? I know that the spring rates are lower with a true setup as the springs are located outboard towards the wheels, the effective spring rates at the wheels are higher.
Won’t you reduce tire clearances or won’t the springs rub against any of the components because of the tighter clearance?
Don
      04-04-2022, 11:27 AM   #10
AWDBooSTIn90
Nomore
AWDBooSTIn90's Avatar
Drives: 335i Coupe 6MT N54
That's good to know. Couple of questions if you don't mind. Do you track your car? What's the benefit of running true coilovers in the rear as opposed to a divorced setup? I know that the spring rates are lower with a true setup as the springs are located outboard towards the wheels, the effective spring rates at the wheels are higher.
Won't you reduce tire clearances or won't the springs rub against any of the components because of the tighter clearance?
Don
Wondering this also! Good thread to talk about advantages vs disadvantages for Rear Coilover conversion setups
