03-27-2018, 10:56 PM | #1 |
Rep 259
M3 engine Fails 45 minutes after purchase from dealer
Hey guys,
So I need to clarify that it was not a BMW dealer. I bought a clean E92 M3 from a dealer in Los Angeles where I live. This car is clean as F***. The car has around 44k miles on it. All the carbon fiber goodies on the exterior from Arkym including the hood, trunk, and diffuser (I believe). The interior had the two tone red and black with carbon trim (including handbrake) and the BMW M-performance alcantara steering wheel as well. The car also happened to come with a full cat-back exhaust system by Mevius as well as a AFE carbon fiber intake. The vehicle was said to never have been tuned but it was a little hard to believe with so many after market modifications. I test drove the M3 before buying it made sure everything worked properly. I turned everything off and did pulls from first to second and into third on the test drive and everything felt amazing. So I got a PPI done at a BMW dealership and I was very quick to speak to the mechanic who would be inspecting my vehicle before and after he was done before he spoke to anyone from the used vehicle dealership I purchased the M3 at. The mechanic told me it fully checked out and everything was totally good, and, "if he were me he would buy it". So with the "green light" from BMW I went to the dealership with my dad and bought the vehicle. I drove the car out of the dealership with my friend on the highway for about 25 minutes. I was sure to let my M3 warm up at the dealership for like 20 minutes before I drove it home. I was gentle on the freeway but I did do a couple pulls as anyone would with their new M3. It was nothing to hard on the engine tho. I went to a exhaust shop that I have brought multiple cars too and swapped in the stock X pipe with some test pipes that were the same diameter as the stock ones. I got no check engine light when I turned her on and it was all good. I drove the car maybe another 20 minutes to my apartment in town. A couple of my buddies that I live with all followed me in their cars (Evo X & F80 M3) to my house in Malibu. I was on the freeway and I was in traffic going maybe 15 mph and my buddy was next to me in his car I was in second down shifted in first which was at like 3200 rpm. I did a small pull to like 6,500rpm and shifted into second and when I shifted the car turned off and rolled into neutral. I pulled it over and stopped the car. I turned it off and tried turning it back on but all that it did was make a click noise I believe from the ignition but did not turn. The electronics worked fine and I crossed out the idea of actuator because it didn't even respond to a jump. It was put on a flat bed and towed to the nearest BMW dealer assuming it might be something with the ECU freaking out with exhaust related malfunctions due to the deletion of cats. I soon found out when they tried to turn it over manually the engine did not crank. It was seized up they said. It was throwing no codes on the computers or anything. I didn't think it could be rod bearing related as it was driving beautifully before it shut down. There was no ticks, the idle was smooth and steady, and there was definitely no knocking noises. The car felt like it did when I test drove it at the dealer and then all of a sudden it shuts off. When I purchased the car the dealer stated on the warranty that everything on the car besides the exhaust because that was aftermarket. The warranty went on to show the engine, transmission, and drivetrain warranty of 30 days or 1,000 miles. The dealer I got it from is a really nice guy and he has paid for the tow trucks and inspections. He wanted to take the car and look at it at his shop as he has a friend who is a BMW tech and was going to work on it, he also noted they would diagnose the problem there and fix it once they did. They have been very responsive with me and have been taking care of this as fast as possible. There mechanic found that there was no metal in the oil so they are going more in depth. Do any of you know what the heck is going on? Please help!
2013 MW E92 M3
2018 MG F87 M2 (Sold) 2016 YMB F80 M3 (Sold) Follow me on Instagram- @dtmpower98 |
03-28-2018, 01:27 AM | #3 |
Rep 257
Clutching at straws, but maybe a transmission issue? If it literally just turned off, and purely guessing, maybe the transmission seized and stopped the engine from turning. It would be unusual, but the only other reason an engine seizes is typically due to major bearing issues, catastrophic rod issues, or maybe hydrolock. Usually most issues will make themselves known before the seizing part (noise, smoke, oil on the ground, etc), which is why I’m pointing at the transmission.
I’m assuming it’s a DCT? Thanks! S. |
03-28-2018, 01:30 AM | #4 | |
Rep 259
2013 MW E92 M3
03-28-2018, 02:14 AM | #5 |
Rep 2,362
Lesson learned: get a manual
Pass me if you can.
Tylenol Jones21.00 |
03-28-2018, 08:00 AM | #6 |
Rep 3,140
Drives: 2014 M5 6MT
Sucks.
PPI can't detect a failing bearing issue. Getting a PPI is for the simple things, brakes, suspension, oil leaks etc. I haven't seen this DCT fail or "lock up" to the point you couldn't turn the engine. You can manually lock the dct in neutral with a zip tie and then retest the manual engine crank. If the engine still doesn't turn, she's toast. Get a lawyer.
2014 M5 6MT
03-28-2018, 10:55 AM | #7 |
Rep 270
Drives: Red
Unfortunate but sounds like the dealer is willing to take care of it, hopefully more of just a hassle for you than anything else.
03-28-2018, 12:26 PM | #8 |
Rep 5,874
Sounds like it was a silent timebomb and it happened to you after purchase and not on some test drive. Hopefully the dealer sticks to their policies and makes it right. I do wonder if the business cost to the dealer is more now to deal with it than if it had failed while in their inventory. If they do make it right, post up the dealership to give them huge kudos.
03-28-2018, 12:39 PM | #9 |
Rep 1,867
This. As long as he has that warranty, which expresses the 1,000 mile guaranty, it's the dealer's problem. They will probably just choose to buy it back, than put a new engine in.
03-28-2018, 06:39 PM | #10 |
Rep 259
Got an Update- the crank hub broke, and it was the crank that was seized, potentially due to poor lubrication/maintenance by the prior owner. They said it would be around a 14 day repair, and an extended warranty would be included into the repair by the third party dealer. The dealer offered to buy back the car, and the manager was quite embarrassed the car did this after they ensured it was maintained well. Do you guys think I should proceed with the purchase? The dealer has not cashed my check yet, as he wants to ensure my satisfaction of the sale.
03-28-2018, 06:49 PM | #11 |
Rep 5,506
It is most likely caused by rod bearings. They usually seize completely randomly. There are many cases where it just seizes with no sign beforehand. My friend's rod bearings seized while idling in a parking lot - the car just shut off and would not turn back on. Dealer found the crank seized and the engine was replaced under warranty luckily.
It may or may not be related to previous owner maintenance but I doubt that is the case. If the dealer is willing to pay for a new engine replacement, it should be fine to purchase. Otherwise walk away. An engine will cost $10-20k for a used engine replacement. If you do go through and get an M3 - replace the rod bearings. It is a known issue on these cars.
Auto Detailing Enthusiast!
03-29-2018, 02:16 AM | #12 |
Rep 5,874
I'm ignorant but what is the crank spur? So how did they diagnose this and what is their fix? Replace the crank? If the crank seized up that can't be good overall and I would also question the RBs or mains. Any extended warranty is probably only good for the repair made so would be careful about that.
03-29-2018, 02:24 AM | #13 | |
Rep 259
2013 MW E92 M3
03-29-2018, 05:43 AM | #15 | |
Rep 724
03-29-2018, 06:05 AM | #16 |
Rep 1,667
Might of been supercharged in the past. I'd be wary of a car with those type of mods. There are plenty of other examples out there, I would move on and find a different car.
03-29-2018, 06:10 AM | #17 |
Rep 63
I was feeling bad for myself a month ago when without warning my engine blew up... but this is terrible! I just hit 50k on my 2012 except it's super charged but I did the bearings at 25k with the SC install.
The more I read about other owners issues with these engines the more I think it's just dumb luck with different parts of the engine tolerances lining up on the wrong extremes. Like others have said, be aggressive with the dealer and any warranty/replacement options. I had a dealer purchased extended warranty on my powertrain and ended up being able to negotiate a brand new S65 vs a donor or rebuilt engine. As others said you may be able to negotiate a stroker/rod/crank bearings but will most likely be a little out of pocket and very much out of warranty. |
03-30-2018, 06:28 PM | #18 | |
Rep 1,348
Better off saving up for a newer M3 with warranty like a 2k14 or 15 and get an extended warranty. These cars get beat on!!
2k15 335i Msport xdrive 6spd
Wagner Comp2 FMIC,FTP CP,stock exhaust. Fabspeed Sport catted DP, KW V2 coil overs,FBO BM3 Stg 2 |
03-30-2018, 07:04 PM | #20 |
Rep 539
This is stupid comment, come on bud
CP-E DP's / Remus Race / ETS 7" FMIC / AFE DCI / Cobb V3 / ETS CP / HKS BOV
03-30-2018, 08:14 PM | #21 | |
Rep 3,965
Dave
dtmpower98336.50 |
03-30-2018, 08:29 PM | #22 |
Rep 3,002
Must have been supercharged before.
Sorry to hear. Better lawyer up if they don't give you back your money!
INSTAGRAM: GORDON.M3
ceedawg467.50 |
