06-12-2013, 07:42 AM | #1 |
Dingleberries
76
Rep 1,246
O2 Sensor Fault Codes - Deciphering Help
MY 03/08 E92 M with pullies / test pipes / air filter / Stage II tune.
I had issues with my Throttle Valve Actuators and got them replaced under warranty (though had to pay a deductible). Now I have some O2 sensor faults (known to be problematic sometimes) so I just want some help deciphering which ones I need to replace. Here are the codes: 27C7 - Lambda sensor trim control AD diagnostic bank 2 2771 - Lambda sensor dynamic diagnostic VKAT bank 1 From my understanding: VKAT = VOR (before) Cat NKAT = NACH (after) Cat bank 2 = drivers side bank 1 = passenger side So it looks like I should replace both before Cat 02 Sensors. Just want some concurence prior to buying the following 02 sensors: http://www.amazon.com/Bosch-17039-Ox.../dp/B000JZEXG8 Thanks for the reassurance! |
06-12-2013, 03:38 PM | #2 |
Rep 158
2771 - P0133
Information saved in: DME Fault code: 2771 - P0133 Fault text: Oxygen sensor dynamic diagnosis before catalytic converter, bank 1 Fault description: O2 Sensor Circuit Slow Response (Bank 1 Sensor 1) Condition for fault identification Test condition: Amplitude of oxygen sensor less than diag. value 0.35 (K_LAVK_OBD_DYN_WERT_MAX) Terminal condition: Engine running - Condition idle or partload Voltage condition: none Condition for fault memory entry: none Action in service: 1. Clear fault memory, oxygen sensor system test 2. Check exhaust system for leaks 3. Replace pre-cat oxygen sensor LSVK B1 Fault effect and breakdown warning: MIL on after engine runs 2x / possible mild effect on drivability...surge during steady-state operation Driver information Warning light: MIL Service instruction: none ===== 27C7 - P2099 Information saved in: DME Fault code: 27C7 - P2099 Fault text: Oxygen sensor, adaptation, trim control, bank 2 Fault description: Post Catalyst Fuel Trim System Too Rich (Bank 2) Condition for fault identification Test condition: Adaptation value reaches max. limit and hangs in this position Terminal condition: Engine running Voltage condition: none Condition for fault memory entry: Counter for recognition at adaptation limit >= (2x) K_LA_TRIM_DIAG_I_AD_MAX_SCHW Action in service: 1. Check the fuel system and the exhaust system for leaks 2. Check pre-cat and post-cat sensors and replace as indicated Fault effect and breakdown warning: MIL on after engine runs 2x Driver information Warning light: MIL Service instruction: none |
06-12-2013, 04:39 PM | #3 |
Dingleberries
76
Rep 1,246
Thanks for the information!
Well I will double check the clamps for my test pipes as well as bolts to the header. If the problem persists, then I should replace both Pre-O2 sensors..maybe post cat on drivers side if the problem persists even more.... Positive reassurance please! Last edited by happos2; 06-13-2013 at 06:12 AM.. |
06-14-2013, 07:52 AM | #6 |
Rep 158
Sorry my friend,very busy at work.
Lets see, i would start by clearing the code and do a drive cycle and see what happens. Your car is an 08 so i would also suggest a fresh set of primary O2s if the codes come back. Also,which tune do you have ? Did all these codes started popping up after the new tune was loaded ? Good Luck and send me a PM if you need help with anything. |
06-14-2013, 11:23 AM | #7 | |
Dingleberries
76
Rep 1,246
I have cleared them once already and then the came back in a few hundred miles. I have had these codes pop up whenever the throttle valve actuator whould act up. therefore I thought it was part of the Throttle valve actuator. this happened all before any tuning was done on my car. |
06-15-2013, 02:23 AM | #8 | |
Rep 158
Follow this and PM me with any questions plz: http://www.m3post.com/forums/showthread.php?t=735033 I would personally change the O2s first cause throttle actuators are pricey |
07-02-2013, 06:47 AM | #9 | |
Dingleberries
76
Rep 1,246
I also checked to make sure my clamps for the test pipes were tight and they were. Now I am not sure what the next step would be. Any suggestions? |
07-02-2013, 01:34 PM | #11 |
Rep 7,541
Did you replace the post cat oxygen sensors or the precat sensors?
07-02-2013, 02:21 PM | #12 | |
Dingleberries
76
Rep 1,246
This one to be exact: http://www.amazon.com/Bosch-16793-Ox...1&s=automotive Last edited by happos2; 07-02-2013 at 02:57 PM.. |
07-02-2013, 10:24 PM | #13 | |
Rep 7,541
11-18-2015, 07:30 PM | #14 | ||
Rep 979
2008 E60 550 ? Alpine White // RPI
2011 E90 M3 Competition // Alpine White // ESS // RPI // 20" BBS LM's, blah blah 2021 G80 M3 Competition // Brooklyn Grey // KW Suspension // 12mm Spacers all around // Resonator Delete |
12-11-2015, 04:22 PM | #15 |
Dingleberries
76
Rep 1,246
This was some time ago...I really don't remember. I only remember replacing my pre-cat sensors (post cats don't really mater after you tune and get test pipes). If you don't have test pipes, then replace your post cat sensors.
12-13-2015, 10:59 PM | #16 | |
Rep 979
04-18-2019, 10:54 AM | #17 |
Rep 135
Guys, I have acrapovic exhaust and last OEM DME software without any tune.
For a long time I had only two DME error codes: 2789 - Catalytic-converter conversion, bank 1 278A - Catalytic-converter conversion, bank 2 So it is normal because acra does not have the cats. Sometime ago I got more error codes: 2727 - Oxygen sensor before cat., bank 2, plausibility 277D - Oxygen sensor trim control diagnosis, bank 2 27C7 - Oxygen sensor, adaptation, trim control, bank 2 So, I desided to replace my pre-cat O2 sensor driver side. Yesterday I replaced it. Today I deleted all error codes and drove my car. Gets approx 100 km and I see the MIL (small check engine light) on my dashboard. I read my error codes again and I see the next errors: 277D - Oxygen sensor trim control diagnosis, bank 2 27C7 - Oxygen sensor, adaptation, trim control, bank 2 What's wrong? Maybe the reason is something other than my bank 2 O2 sensor? |
