06-11-2016, 05:51 PM | #2 |
Rep 4,488
You could just....turn it off. AC delete is usually for weight savings, but a bypass pulley isn't going to help you there.
06-12-2016, 08:14 PM | #3 |
Rep 8,075
Drives: 11 E90 M3 Individual
Actually, you delete the A/C to improve cooling. The condenser blocks the radiator and heats up the air before it hits the radiator. There is a significant benefit.
Kind of pointless unless you remove the condenser.
2018 F30 320iX Melbourne Red
06-12-2016, 11:32 PM | #4 |
Rep 305
Thanks for advice, guys~
Ultimately, A/C delete is needed for track only car. But, pulley, shoter belt or some kinds of kits are not shown on internet. Racing teams make parts for a/c delete, individually? |
06-13-2016, 01:53 PM | #5 |
Rep 1,718
Would like to know as well.....!!!!
06-13-2016, 02:12 PM | #6 | |
Rep 5,484
http://www.realoem.com/bmw/enUS/show...diagId=11_4120
06-16-2016, 07:34 AM | #7 | ||
Rep 1,718
I have also attached the pre 09 cars. which might just be able to change belts size, but on the 09+ the PS pump goes the other way.
06-16-2016, 07:37 AM | #8 |
Rep 1,718
pre 09 belt
06-22-2016, 02:45 PM | #9 |
Rep 406
shortcut condenser?
Question.
Shortcut the condenser lines and take condenser out? Will the AC compressor survive w/o condenser? Any other issues with this 'solution' ? That would be the quickest way to increase cooling power of existing radiator. Anybody any experience with that? Thanks
ST-60 / MCS 3-way / Solid subframe / Full cage by JPMarketingllc.com / 315-30 square / GT-250 / JPmarketingllc.com Aero Stage2
06-22-2016, 02:49 PM | #10 | |
Rep 1,718
I will post pics here if the solution I am working with next week.
06-23-2016, 03:47 AM | #11 |
Rep 305
Thanks for good advice
Is it possible that PS pump runs in reverse? Last edited by maicol76; 06-24-2016 at 08:41 AM.. Reason: wrong word |
06-23-2016, 08:27 AM | #12 | |
Rep 5,484
A shorter belt looks like it might do the trick though
07-29-2016, 09:29 PM | #13 | |
Rep 406
AC delete
Any luck with the 'looping' of the condenser lines? Does it work? Can you post pictures? Thanks!
07-30-2016, 12:33 PM | #14 | |
Rep 1,718
Yes did have success in looping line. I will post pics once i am back in town. Basically you are taking out the Freon, then the condenser, then looping the in/out line of the a/c line....hope that makes sense. Works great on track and only issue is some time it might throw a CEL since the ECU looks at the AC pressure to see if everything is working. no power pull or any side effects noticed. Seems to have freed up some cooling to the radiator. But I am still going to seal up the air flow to the radiator to improve cooling.
