07-20-2016, 10:09 PM | #1 |
Rep 2,492
Trailer tie down location ideas
Good evening M3post! I just bought a car trailer and am thinking for ideas for tie down points. I typically use straps through the wheels, but am learning that is not a great idea as it can pull the car out of alignment. Before anyone suggests the hooks that go into the jack pads, i do not have enough room to get under there to mess with that on the trailer, nor do i feel like pulling the jack pads every track day.
I was thinking of getting a few of these, but am interested to see where you guys would put them. I could anchor them to the rear lower control arm 21MM bolt, but that may have the same effect and pull the car out of alignment as well. Maybe rear subframe bolt facing down? But, that would not give the suspension any travel while on the trailer, which I am reading is also important. http://www.stableenergies.com/Rennli...fo/REN-E04/90/ Any input would be greatly appreciated.
2010 E92 M3 DCT
07-20-2016, 10:52 PM | #3 | |
Rep 2,492
No alignment issues?
2010 E92 M3 DCT
07-20-2016, 10:57 PM | #4 |
11817
Rep 23,187
My d rings at the front pull almost straight ahead of each wheel. At the rear I locate a j hook on the dovetail rail and can slide wherever, but put straight back of the tire. Only time I had alignment issue was on original shipping they ratcheted down too tight at angles.
07-20-2016, 10:58 PM | #5 |
11817
Rep 23,187
Another option would be to get a sling style that loops over tires and attaches straight down to flush mounted rings on the decking, fore and aft of each tire.
07-20-2016, 11:43 PM | #6 |
Rep 266
Not really an answer to your question but I had a few extra D rings welded to a trailer of mine at a trailer place. I don't remember what it cost it wasn't very much. Trailer is used, among other things, to carry a small tractor; no BMW experience yet.
07-21-2016, 02:20 AM | #7 | |
Rep 2,492
2010 E92 M3 DCT
07-22-2016, 08:00 PM | #9 |
the me
342
Rep 318
http://www.macscustomtiedowns.com
They can get you set up, thinking wheel nets, etrack, and remote the ratchet straps. Give them a call, they will set you up. I use their stuff for the jeeps.
01 Z Coupe, 5MT, SB, not much else
08 M3 Coupe, 6MT, JB, not much else 21 M2c Coupe ,DCT, SOM, not much else |
07-23-2016, 07:00 PM | #10 |
Panty Schtuffer
21
Rep 320
Drives: 2008 E92 M3 Coupe
You want holes/perforations in the trailer floor so you can do this
http://www.take3trailers.com/SoftTie...shings_001.jpg |
