12-15-2015, 10:05 AM | #2 |
Rep 1,485
Drives: 2011 Frozen Grey E90 M3
Thanks for sharing.
12-15-2015, 10:56 AM | #3 | |
Smiling Politely
1381
Rep 29,118
Neat
12-15-2015, 11:28 AM | #4 |
Currently Driving
269
Rep 1,426
Drives: BPM tuned '13 AW ZCP E92 M3
I wonder if this kind of technology will be used in other applications going forward. It's a great idea.
12-16-2015, 10:08 PM | #7 |
Gateropode
329
Rep 2,848
Looks like extra weight to me. The compressed air tank is not going to be light.
They had a plan for rolling electric turbos at some point, what happened to that? Sounded like a lot less junk to carry around. |
12-17-2015, 06:04 AM | #8 |
Rep 232
Instead of using the compressed air to spool up the turbo why not just pipe that extra air into the throttle body that would also eventually make the turbo catch up.
12-18-2015, 09:11 PM | #10 |
Rep 3,470
12-30-2015, 02:50 AM | #11 |
Savoir Faire
74
Rep 1,772
Maybe because the compressor would always have to be at the same pressure as the turbo and this would be tricky to engineer since the turbo is never at a fixed PSI
Current: Alpine White F10 M5|H&R springs|12mm/10mm spacers|Eisenmann Race
Sold:Imola Yellow RS4-KW V3|MTM 10mm spacers|Hotchkis rear sway bar|APR Stage 1|Milltek Catless|RNS-E|Euro RS4 Flat bottom Steering Wheel Sold:E46 323i |
12-30-2015, 06:42 AM | #13 |
Rep 376
More things to go wrong. They must use software to correct the O2 sensor reading since adding air to the exhaust would probably read as a lean condition.
ER CP, Forge DV, Wagner FMIC, PE, Maddad Mid, ER Sports OC, BMS OCC, RB Check Valve, AFE intake, Cobb AP3- Stage 1+ drive, BMW SS, PS Springs, Yellow Koni external, M3 Control Arms F & R, M3 Strut Brace, M3 Sub Bushing, Rouge Toe, Dinan Camber Plate and Rear Shock Mts., E93 M3 front sway bar, Mfactory Diff, Arc 8 PSS 235/40/18-265/35/18
12-30-2015, 01:00 PM | #14 |
Rep 918
Now that the Chinese own Volvo, (purchased fro Ford in 2010) I'm sure they will come up with a fool proof setup even if they have to copy it from somebody else. LOL
12-30-2015, 06:41 PM | #15 |
Rep 912
That's a pretty neat solution to the lag problem, I question its efficiency in terms of duration. I would make more sense (to me) to inject the pressurized air directly into the intake and add gas to compensate for the lack of pressure. This in affect is just allowing it to spool up faster.
12-31-2015, 10:35 AM | #17 |
Custom User Title
1137
Rep 675
