11-14-2015, 03:10 PM | #1 |
Rep 339
Is upgraded brake setup necessary after installing supercharger
I was thinking of having a supercharger installed in my car and this would be my first time. How much can the stock brake setup handle? Do I necessarily need to upgrade my brake system (calipers/rotors/brake pads/full system)? It probably won't see much track use for at least a year, cause I'm just planning on driving it in SCCA. Also since we don't have a real track here in Hawaii
11-15-2015, 02:40 PM | #3 |
Rep 341
Drives: 2011 E90 M3 W/ ZCP, ZPP, ZCW
It is not necessary by it is highly recommended. At a minimum I would upgrade to braided lines, RBF 600 or 660 fluid, and Stoptech street pads or something comparable. I am in the middle of installing a ESS VT2-625 and chose to upgrade to Stoptech ST60F and ST40R. It also will depend on how hard you drive it but I would guess considering you are installing a SC you will be driving hard so better safe than sorry!
E90 M3 W/ ESS VT2-625, Macht Schnell race X-Pipe, UUC Cat-back exhaust, Stoptech ST60
11-15-2015, 11:26 PM | #5 |
Rep 12,722
if you aren't tracking, you don't need it. i highly doubt you can fade the oem brakes on the street without attracting a lot of attention and driving pretty stupid.
11-15-2015, 11:42 PM | #6 |
Rep 979
My general rule of thumb is for every dollar spent on go-bits, spend .50c on brakes.
Mods: too many the list wont fit in the sig page. PM me
Tesla Referral code: http://ts.la/juliana77782 |
11-16-2015, 12:26 AM | #7 | |
Rep 1,611
may I add: at least .50c on break's better more As for break upgrade, track user's only strategy: Better be safe, then sorry ...it's a public road that you are up to operate your high powered vehicle, hence if something break's ...there are alot innocent people involved in your game play. |
11-18-2015, 09:59 AM | #9 |
Rep 5,484
Disagree. Driving the stock stuff hard will fade it, it doesn't matter where you drive it hard. Whether you should drive hard enough to fade M3 brakes on the street is another discussion but in my experience anyway, two or three threshold braking events in quick succession from highway speeds is enough to fade te stock stuff. Particularly the fronts of course. No ducting plus heavy heavy car and true street pads = crap performance when you push a car.
However, agree a set of track capable pads solves that problem but at the expense of noise and rotor wear |
11-18-2015, 10:33 AM | #10 |
Rep 1,320
roastbeef is right here. BBK's are supposedly better at dissipating heat, hence their primary use on the track, due to the speeds and frequency of usage in that setting. But on the street, why would added power immediately imply that a BBK is required? If the user isn't driving rashly and constantly speeding up and slowing down, I think the stock brakes will do just fine. Purely cosmetic for a street car.
Just an opinion and thinking about some of the science behind why a BBK is necessary in the first place or any scenario... |
11-18-2015, 11:10 AM | #11 |
Rep 691
Our shop E92 with our kit stopped plenty fast with a good set of brake pads. There is no need to upgrade if you do not need to. The stock setup with fluid and pads are good enough to handle the added power.
Plenty of guys on here have a supercharger and stock brakes. |
pskills19.50 |
11-19-2015, 11:10 PM | #12 | |
Rep 101
