02-06-2010, 05:37 PM | #1 |
Akrapovic HK
68
Rep 265
Full AKRA & ENVY (CODE updated)
Hi guys, has anyone here with mods only on full AKRA and Full Envy intake.
i have been investigate this for a long time, after i install the Full akra, i could actually feel the car is way faster, and it spin at 6krpm 2 - 3gear. it has put a smile on my face for 3K km, and then i went for the full envy. after the Full envy install with MS filter, for about 500KM, when i had my cruise control on, the car's engine checking light came on, then bought it to diagnostic, the msg is intake mass air sensor error. they reset it, and it was all right. the main point is, i actually think the car is slower now, with somekind of lack during the RPM range as well. ( the reason i said it is slower, is becasue it doesnt even spin at 1-2 now at max rpm. anyone with those 2 mods please? and does anyone know the reason to that please?? any input will be welcome, thanks Last edited by ahtim; 02-10-2010 at 05:57 AM.. |
02-06-2010, 05:39 PM | #2 |
Sauce
75
Rep 2,023
Contact Eric@PYSpeed. They sell both, he may be able to help.
2009 E90 M3 | Silverstone II | Black Novillo | HRE P40's | Akrapovic Exhaust | Eibach Pro Kit | Jet Black Kidney Grilles | SSII Side Reflectors | SSII Side Gills | LUX H8 Angel Eyes | Macht Schnell Filter | Tecnocraft Envy Charge Pipe
"M3 drivers have no friends." - Jeremy Clarkson |
02-06-2010, 06:37 PM | #3 |
12
Rep 84
I would PM Eugene-TAIWAN, unless you bought the item from Eric@PYSPEED, he won't respond bc I tried emailing him and he ignored my email when I didn't buy my ENVY intake from him. I would contact Sam@Autotalent as he helped me out when I had issues with mine.
Eugene-TAIWAN had the same issue before but I think he solved it from doing a software tune on his car. |
02-06-2010, 08:06 PM | #4 | |
Akrapovic HK
68
Rep 265
02-06-2010, 08:29 PM | #5 | |
Rep 18,802
Drives: BMW
02-06-2010, 09:34 PM | #6 | |
Sauce
75
Rep 2,023
02-06-2010, 11:54 PM | #7 |
Rep 3,157
same thoughts here
Past: Gintani stage3 M3, Cayman GTS present: Porsche 993RWB, 964RS America,996 cupcar, 964 turbo 3.6,Macan Turbo,997GT2,930 turbo,i3, MINI JCW |
02-07-2010, 12:04 AM | #8 |
Rep 3,157
Yo Brother,
I even called up BMW for you and its not possible to have that kind of error. It can ls be the vacum hose that connects to the charger pipe that came loose. the that pipe has to be tight. so check your installation and make sure everything is right. your on the only with this kind of problem I have seen with an exhaust and intake set up. talk soon
02-07-2010, 04:38 AM | #9 |
Akrapovic HK
68
Rep 265
O really? i didnt actually read the computer with the MAF error, but he told me it is the MAF error.....
but it couldnt really be the exhust, could it? coz i had the thing to trick the o2 sersor. |
02-07-2010, 03:41 PM | #10 | |
Rep 6,094
In our general observation, while not paired with an Akrapovic system, our initial dynamometer tests indicate gains when paired with Meisterschaft GT exhaust systems - indicated in the total 18WHP gain over baseline (with just the exhaust system installed). The issue of MAF errors appearing with use of our system is the first of its kind and hopefully the issue is duplicated? We've had many ENVY owners successfully install the intake system without issue or power loss when paired with other after-market exhausts. In this case, it may just be a random hiccup in the vehicle indicating errors. The system definitely doesn't lose power, and in our dyno tests... have yet to lose power. Hope this help ~ Eric =) PYSpeed.com |
02-07-2010, 04:43 PM | #11 | |
Akrapovic HK
68
Rep 265
do u think the fitment could cause hot air into engine? ( i mean the electric tape gap) thx |
02-07-2010, 04:46 PM | #12 | |
Rep 6,094
Electric tape is specifically designed for the ultimate seal purpose, so no, it's not the reason. Eric =) |
02-08-2010, 02:24 AM | #13 |
Moderating
418
Rep 2,047
Hi I have an Akrapovic Evo system with a map, and its much quicker!!
In my humble opinion, I think the Akra system needs a map in any event, 1, to sort out the CEL issue and also the reduced back pressure. I am sure now with the increased lung capacity from the Envy, you will need the tune, but I suppose the fitment issue could be the reason, maybe rechecking the install piece by piece, will solve it, Get a remap!! Last edited by Bob MG; 02-08-2010 at 03:30 AM.. |
02-08-2010, 10:51 AM | #14 | |
Akrapovic HK
68
Rep 265
unluckily i was cruising today at 100km, with my foot holding still (not cruise control) the engine checking light came on again!!! any one?? |
02-08-2010, 11:10 PM | #15 | |
Akrapovic HK
68
Rep 265
anyone? is is more related to the charge pipe? |
02-09-2010, 01:58 AM | #17 |
Rep 18,802
Drives: BMW
We should find out the exact code that is being reported before starting any work.
When you report the check engine light "came on again", I'm assuming the light is turning off at some point or are you having the codes cleared?
02-09-2010, 07:55 PM | #18 | |
Akrapovic HK
68
Rep 265
but it came back on again on monday, and i tryto change the filter from MS to stock, and drove for a bit, but still on |
02-09-2010, 08:09 PM | #19 |
Rep 18,802
Drives: BMW
Until we know the source of the code, any advice given will be inaccurate.
02-09-2010, 11:32 PM | #20 |
Moderating
418
Rep 2,047
02-09-2010, 11:41 PM | #21 | |
Moderating
418
Rep 2,047
2. To prevent the CEL you mentioned that you had a power loss. Is that fixed after checking the install of Envy? I spoke to Ralf and it's impossible to lose power from envy The car can run with airbox removed |
02-10-2010, 02:25 AM | #22 | |
Rep 1,179
The more you cruise the sooner it shows up, the more you use the car real hard the later it comes. Thatīs because the ECU only takes lambda into account, when cruising. C U next week |
