08-02-2016, 06:34 PM | #2 |
Rep 413
08-02-2016, 09:44 PM | #3 |
Pwrdbym
60
Rep 343
well i have had transmission fault codes.
5a41 pressure sensor clutch 1 total failure 5a43 pressure sensor clutch 2 total failure 5a61 selector rod 1/3 fault also sometimes the car shifts on its own even though its in manual mode my car is a 2010 m3 and has 74xxx miles. i bought the car with 40,000. according to the shop that read the codes i need new clutches, but the clutches dont slip at all no matter how hard i accelerate. |
08-03-2016, 07:36 AM | #4 |
Rep 413
the first two codes combined with the 3rd code would lead me to the wiring harness first. The pressure sensor codes are only generated when the signal returned from them in implausible, not when the actual pressure is out of range.
As the SMG3 ages, what we primarily see as causes of failure (aside from the silly brushed DC hydraulic pump motor) are wiring harness degradation on the hall sensor strips and the control wiring for the shift solenoid valves. Apparently, all BMW wiring insulation is crap, not just that inside of headlights and tail lights that have been recalled lately. It would be worth a thorough inspection of the main wiring harness from the E-box down to the DCT, especially the large round barrel connector. These are usually where I see wiring problems start, either from the insulation nearest the connector pins, or an actual connector pin that was pushed back out of the shell when a transmission was removed for service. The harness is available separately as well, item 2 here: http://www.realoem.com/bmw/enUS/show...diagId=61_2289 I would almost guarantee it is electrical in nature give the symptoms you described. |
08-03-2016, 02:04 PM | #7 |
Rep 2,907
Drives: 2011 E93 M3
I agree with Jay with the electrical suggestion. I have seen SMG and DCT transmissions both with wiring so brittle that the insulation was cracked and had fallen away enough for the wires to touch eachother if they moved just a little bit, especially on or near the transmission connectors. Your car is old enough that I would check that as a suspect.
10-04-2016, 03:21 PM | #9 | |
Ultimate Driving Machine E92ESS625 M3/G05 X5 Msport 40i Individual
459
Rep 2,002
Drives: 2011 E92 M3 DCT/ESS 625 kit
"The Ultimate Driving Machine"
2011 E92 M3 supercharged ESS 625 2016 F15 X5 Msport 35i |
10-05-2016, 07:39 PM | #11 | |
459
Rep 2,002
10-11-2017, 03:05 PM | #12 |
Rep 1
5A5B - Control valve PV7: valve jammed
Hi guys,
You might know what to do... I had 17 times in the computer the error code 5A5B - Control valve PV7: valve jammed. The car runs well, nothing to feel. New mechatronics is needed, at least it was told to me at the workshop - without checking the car. Do you have any experience/idea? Thanks a lot! |
10-11-2017, 03:20 PM | #13 |
Rep 2,907
Drives: 2011 E93 M3
That's a rare failure. Not sure of the code details but fixing it will not be financially viable unless you know of a specialist that repairs these mechatronics units.
If it doesn't affect the driveability, you could keep driving it until the DCT fails altogether, then just replace the transmission. Or, replace it now if you don't want that hanging over your head. |
