08-24-2016, 10:21 AM | #2 |
Rep 151
are the batteries dead in the remotes?
Godchild1452.00 |
08-24-2016, 09:59 PM | #3 | |
Rep 263
R3DVelvetM3
08-25-2016, 09:19 AM | #4 |
Rep 84
Not the batteries something with a antenna issue in the trunk... wanted to know if anyone else experienced the same thing, and the e92 m3 key bay doesn't charge the key as I sadly learned, which is hella stupid.
08-25-2016, 03:30 PM | #6 |
Rep 154
Why would you key bay not charge the key? There are only two types of key.
The "regular" keys with an rechargeable battery. The comfort access with "normal " batteries to change out. Go to a pepboys or similar and check if your keys are working. They have a little machine on the counter to check for a signal. |
08-30-2016, 09:53 AM | #7 |
Rep 84
08-30-2016, 01:12 PM | #9 |
Rep 947
08-30-2016, 01:32 PM | #10 | |
Rep 1,374
a rechargeable battery or built-in bs key costs hundreds of dollars to replace and re-coded and is pain in the ass. sometimes newer tech isn't always the best solution, a simple old tech is good enough
