01-15-2018, 04:32 PM | #1 |
Merlin
474
Rep 730
Drives: 2012 BMW M3 6MT w/ZCP
HydroSilex Recharge-works great-any Chemical Engineers on forum to explain?
Greetings,
So I finally tried the new spray on ceramic coatings, HyrdoSilex is weird in that you can apply right after the rinse the car, wait just a second or two and then rinse until clear. Now how this actually adheres to the car I don't know - but it does appear to make it 'shinier' and more glossy. Any chemical engineers on the forum to explain how this is possible? Cheers, Merlin
2012 E92 M3 ZCP | 2008 E90 335xi | 2008 E90 335i | |
01-16-2018, 10:09 AM | #3 |
Rep 13,780
Just grabbed myself a bottle of it and once it gets a little nicer out i'm going to give it a whirl. I've been on a powerlock kick with collinite 845 combo. My car doesn't currently have a ceramic coating on it and i'm intrigued to see the ease of use along with performance of the product
01-16-2018, 10:30 AM | #4 | |
General
63418
Rep 24,687
01-16-2018, 11:09 AM | #5 |
Rep 1,667
My car has two layers of AMMO Reflex and Skin on, looks absolutely fantastic (when it's not covered in winter grime!). These spray on instantly rinse off type coatings appeal, but they seem suspiciously easy to apply and not convinced they will last. Interested to see what results folks get if they try this.
MachinesWithSouls4835.50 |
01-16-2018, 11:21 AM | #6 | |
BMW Veteran
310
Rep 503
01-16-2018, 12:15 PM | #7 |
Rep 880
Drives: 2011 E90 M3, 2019 F150
I try to stick with the philosophy of, "If it seems too good to be true, it probably is".
01-16-2018, 07:50 PM | #8 |
Rep 2,442
Drives: 2022 M3 6MT
I use the AMMO regiment also, and I'd doubt these claims. First, if you've used a synthetic sealant like Skin, you know that it's very sticky and viscous, not a thin spray at all.
Second, they show people using this on a wet car. How can it bond properly if there is a layer of water between it and the car? If you wash the car and dry it, then use this, what do I do? Rinse it off again? So then I have to wipe it down again?! No, no thank you.
2022 M3 6MT - Portimao Blue Metallic
2022 X3 M40i - Tanzanite Blue Metallic |
01-16-2018, 09:01 PM | #10 |
Rep 561
I had my car coated with Gtechniq Crystal Serum Ultra plus EXO. Car looks amazing and the coating works pretty well. I am yet to see a hard water spot which was very common before. There is a 9 year warranty on the coating.
Have I not had the Gtechniq stuff, I'd most definitely give this HyrdoSilex stuff a try. |
01-16-2018, 09:14 PM | #11 |
Retired Curmudgeon
2985
Rep 4,047
Witchcraft is how it works. Plain and simple. (and I have a ChemE degree).
Next thing you'll tell me is that the earth is round. Poppycock I say!
jeff@autocouture965.50 aus891.50 |
03-11-2018, 08:54 PM | #12 |
Rep 6,916
I'm not a chemical engineer but I do have some experience, it does work extremely well. We have seen great results.
A few shots of the results we have had Stand alone Over OptiCoat that we applied two years ago beading shots Stand alone over a Tesla Model S Stand alone over this GTR that we corrected Beading shots over a Toyota Sequioa Gloss is there and ease of use is there, so far we have seen it last over 3 months, Hydrosilex is claiming up to 6 months as a stand alone, if this is the claim and we are half way there the easy and time savings alone is worth it. Just my 2 cents. We have used gallons of this stuff now and it's only improved our efficiency and customers are loving it. So much that we started to carry it. HydroSilex Recharge |
admranger2984.50 |
03-11-2018, 10:11 PM | #13 |
Rep 5,506
At 3 months durability, it's on the same level or less than other sealants out there. I don't really see the point of using it over any other sealant. I use Gtechniq C2 and that gets 8 months durability plus it hides light marring. Just spray and wipe.
Auto Detailing Enthusiast!
03-12-2018, 07:07 AM | #14 |
Rep 6,916
you realized I said 3 months and going strong. not it will last 3 months.
the product came out about 3-4 months ago and we have been testing it real time, thru out our wintery months on the east coast. I will report in month 6 and so on. |
03-12-2018, 08:19 AM | #15 |
Rep 1,667
Those pics look great, and I know at DD you guys do great work and are well known in the detailing world. However in those pictures the paint is contaminant free, fully corrected, and the lighting is perfect. If you did a panel side by side with another sealant i'd wager they look basically the same...
03-12-2018, 09:27 AM | #16 |
Rep 1,930
I tried this stuff out and imo for the $$ it's not worth it. My sonax net shield works the same as this for half the cost.
If you apply when wet, I notice a lot of streaking. On dry application, its a bit better. Not as slick as I thought either. My meguairs ultimate detailing spray gives a better shine and slicker surface. |
03-12-2018, 08:34 PM | #17 | |
Rep 6,916
03-12-2018, 09:14 PM | #18 | |
Rep 5,002
If I fully corrected a car I'd absolutely grab a ceramic coat (CQuartz, etc.) bc it goes on much faster and lasts years as opposed to months. It protects my hard work (the polishing) so much longer. My car sits on the streets of SF and is pummeled by fall out. Once a year I give it an Iron-x bath and about 3 times a year I use Re-load spray-on ceramic as a top-up and It always beads right up, feels smooth and shines. Been good for 3 years since my first CQuartz application. I only wash this car about 1once every 2 months. It only takes one ceramic use to realize sealants are the new wax. aka - they're dead. Last edited by tlow98; 03-12-2018 at 09:44 PM.. |
03-12-2018, 10:13 PM | #19 | |
Rep 6,916
reload can be used as a stand alone product just like fictech car gliss and nanolex si finish, these were made to work with their respective coatings and can be used as a stand alone. So for me a products like this are more effective over a product that can leave residues or need to be applied with a machine polisher etc. spray on buff off and do a car in minutes over hours etc. hopefully this make sense. I can do a product like recharge or reload much quicker then pulling out a liquid sealant applied with a machine etc. or maintain a coating with ... |
03-13-2018, 03:00 AM | #20 | |
Rep 5,002
03-14-2018, 05:41 PM | #21 |
Rep 564
Looks a lot like HydrO2. I have a bottle of that stuff and while in theory its great, the end results aren't. Every time I've used it, it never worked as described, even with the right dilution. It left a lot of residue and streaking... and applied as instructed.
2009 E90 M3 DCT IB Slick Top | 2017 911 Carrera White 7MT Slick Top | 2003.5 E46 M3 CB SMG | 2005 Audi A4 USP Black 6MT |
10-25-2018, 08:51 PM | #22 |
Rep 771
Hydrosilex is the real deal !!!! Don’t knock it unless u try it. I was also a skeptic until I tried it. Works exactly like Carpro Reload. It is a SiO2 product. I use it on everything and am amazed at how good it is. That’s why u see everybody raving about it. And yes, u can just spray it on and rinse off. Done. It’s Magical 🎩
