11-08-2021, 09:57 PM | #1 |
Rep 207
e90 M3 strong exhaust - stock
I have a 2011 e90 M3 that is completely stock.
Recently I had an oil leak and oil smell and very strong exhaust smell. The valve cover gasket was replaced three times to fix the oil leak hopefully for good. The exhaust manifold gaskets were replaced last year due to a very small leak. The exhaust smell still remains. When sitting at a traffic light, the smell is so overwhelming in the car, I need to open the windows. It is bad when the car first starts, when it is returned warm to the garage, or when idling. The exhaust system has been inspected and no leaks found, but there has to be something huge. I am the only owner and never has the exhaust been this strong and it noted by my wife as well as being awful. Does anyone have any suggestions of where to hunt for this issue and what the cause could be?
2011 E90 M3 Jet Black/Black
ZPP, ZCP, ZTP, ZCW, 6FL, PDC, shades, 6MT |
11-09-2021, 04:27 AM | #2 |
Rep 242
Check if the small donut gaskets are installed and not falling apart at where the headers connect to the primary cats. Also, ensure the torx bolts at that connection are tight, should be torqued to 20 ft-lbs. An exhaust leak at this location can be quite smelly.
akkando5872.50 |
11-09-2021, 11:15 AM | #3 |
Rep 801
Do you have excess exhaust noise? An exhaust leak of the scale that you're describing would be catastrophically loud on the S65.
Frankly, the symptoms that you describe sound a lot more like oil dripping on your exhaust than an exhaust leak. Did they replace your valve covers, or just keep replacing the gaskets?
11-09-2021, 12:55 PM | #4 | |
Rep 207
They replaced the gasket only. Some paint was chipping on the covers which may have been the culprit leading to multiple failures, but they cleaned up the sealing surface to help with that. That was last week and the exhaust smell is same before and after that fix. I haven't noticed any change in exhaust noise in the car. My wife says it sounds different from outside, but not sure how accurate that is.
01-18-2022, 04:07 AM | #5 |
Rep 7
hi mrh335! Did you resolve your smell problem? I am dealing with what seems like the exact same problem. Faint smell of exhaust fumes when the car is moving, which becomes uncomfortably bad when the car is running stationary at a light. As I am typing this, just having a though...I should prolly crank up the AC immediately after starting the cold starting the car to see if its oil dripping on exhaust headers problem.
In any case, please chime in with the status of your problem. Cheers, Kman987 |
01-18-2022, 10:24 AM | #6 | |
Rep 207
01-18-2022, 12:15 PM | #7 |
Friends don't let friends ESS
3224
Rep 888
I'd say you are burning leaking oil falling onto the exhaust header rather than an exhaust leak - based on your observations and what else is going on. Are you getting any fouling of dirt/grime around either of the oil separators? these are black plastic devices that come off the valve covers and connect up to the plenum. you can get leaking of oil around the base or where they connect to the plenum. I solved the leak by replacing the gasket on each of side and scraping away the chipping paint layer on the valve cover where the gasket sealed - so I had bare metal all the way around where the oil separator gasket sits against the valve cover. My mechanic thought it was a leaking valve cover gasket and it was actually this - so if you've gone through 3 valve cover changes maybe they missed the source and you've got oil leaking down onto the exhaust header.
