11-26-2015, 08:48 PM | #1 |
Ultimate Driving Machine E92ESS625 M3/G05 X5 Msport 40i Individual
459
Rep 2,002
Drives: 2011 E92 M3 DCT/ESS 625 kit
Recently purchased. Current size 255/30/20 et 15 285/30/20et20
I am rubbing at full turn with Michelin pilot sports. Not sure if I should go 245/30/20. Car is lowered on swift spec r springs. Any recommendations in tire manufacture so I can avoid rubbing in the front. Also looking up recommended tire pressure for this size. I was looking at new pss,Bridgestone,continental Ur feed back would be appreciated !
"The Ultimate Driving Machine"
2011 E92 M3 supercharged ESS 625 2016 F15 X5 Msport 35i |
11-26-2015, 08:50 PM | #2 | |
459
Rep 2,002
11-29-2015, 10:06 PM | #3 | |
Rep 978
Edit... Ok same size as you, slight rub on turns like I said, I do however have the competition package, so while I'm a tiny bit lower them stock I may not be as low as you.
2008 E60 550 ? Alpine White // RPI
2011 E90 M3 Competition // Alpine White // ESS // RPI // 20" BBS LM's, blah blah 2021 G80 M3 Competition // Brooklyn Grey // KW Suspension // 12mm Spacers all around // Resonator Delete |
12-29-2015, 09:22 PM | #4 | ||
459
Rep 2,002
M3LISSA786.00 |
01-13-2016, 03:25 PM | #6 | |
459
Rep 2,002
01-13-2016, 08:32 PM | #7 |
459
Rep 2,002
Any thoughts on invos 255/30/20 and 285/30/20. I like front and rear tires looking even in diameter. Seems like the rear tires on my current set up are taller then the fronts
01-14-2016, 08:48 AM | #9 | |
459
Rep 2,002
And keep 255/30. Searching but not much I can find with this set up. 245 looks way to thin.
01-18-2016, 12:34 PM | #10 | |
Rep 3,964
A 255/30/20 tire is 26.5" in diameter. Way beyond the max 26" recommended for the front. The front is rubbing not because of width but height. This is the issue with 20" wheels, not much available for rubber. A 245/30/20 will be under 26" and should work, but to go narrower up front? I am running 275/30/19 on the front of my car with a 10" wide wheel, but they are only 25.6" tall and I have no issues. Dave
01-18-2016, 12:37 PM | #11 | ||
459
Rep 2,002
01-18-2016, 02:48 PM | #12 | |
Rep 3,964
They have 275/25/20 and 295/25/20 available...I would consider this. Dave
01-18-2016, 02:51 PM | #13 | ||
459
Rep 2,002
I just find the 245 in the front is stretched with a 9 inch rim compared to a 255/30
01-18-2016, 06:18 PM | #14 | |
Rep 3,964
Dave
01-18-2016, 06:21 PM | #15 | ||
459
Rep 2,002
20 x 9 et 15 front 20x 10 et 20 rear 245/275?
01-19-2016, 03:30 PM | #16 | |
Rep 3,964
Did you spec the wheels out or did you just buy them with that offset? Dave
01-19-2016, 03:33 PM | #17 | |
459
Rep 2,002
A lot of guys are saying I should be fine with nittos or toyos michelins are more square which cause rubbing at full lock.
01-19-2016, 06:24 PM | #18 | |
Rep 3,964
Dave
