04-11-2014, 09:34 AM | #1 |
Rep 3,482
Wet air filter?
So, I washed my car yesterday. We haven't had gorgeous weather in a while and I wanted to snap some pics. I also got an Agency Power CF elbow and wanted to knock that out before the afternoon was up.
I wash my car like any car enthusiast... rinse, soap and scrub by hand, rinse again, dry. Well, I let the car sit for a bit and then popped the hood for the install. When I opened the air box, I noticed a tiny puddle under the filter and the element was moist. Luckily, the inside was dry, but I found that odd. TL;DR My ultimate question is, will closing off the hood vent - or hindering some of its flow affect the car in any significant manner? I also stuck a metal rod through the hole where water should drain out before it's supposed to reach the filter, but it didn't feel or look clogged.
BMWCCA:518970 |
04-11-2014, 09:46 AM | #2 |
Rainbow Racer
1008
Rep 2,539
I tried it for a week just to see, I didn't feel any big detrimental effects other than not being able to hear that lovely induction noise the S65 is known for (that hole is why our induction noise has such a prominent growl). However, the car was more susceptible to an initial "heat-soak" sensation because it's not breathing the cooler air from that vent, but that went away after the initial acceleration. The front nostrils get "cool" air, but they are located above a hot element (the radiator).
-Loe P.-
Prior Car:'14 Audi S5 3.0t DSG [ APR ECU/TCU | Pullies + basic bolt-on mods | 10.861@127.90mph ] Current Car: F82 M4cs | TT-RS | On Order: i4 M50 |
04-11-2014, 09:53 AM | #3 |
Rep 3,482
Hmmm... I need to see where the "drain" leads to. I'm assuming its still clogged if there's a bend or curve in the pipe.
This is just a stupid problem to have. I don't even have a high pressure washer, lol.
BMWCCA:518970 |
04-11-2014, 09:59 AM | #4 |
Rainbow Racer
1008
Rep 2,539
yes, by all means, i would figure out why the water isn't draining too.
-Loe P.-
04-11-2014, 10:01 AM | #5 | |
Rep 3,482
Edit: Sorry, saw you had it blocked just for a week.
BMWCCA:518970 |
04-13-2014, 09:24 AM | #7 | |
Rep 3,482
The drain for the intake is clean, so I'm thinking the flow of water surpassed the draining capacity. It's not like I sat with my hose aimed at the vent either . Ugh, I guess it wouldn't be hard to seal that vent with some rubber or plastic during the aforementioned times.
BMWCCA:518970 |
04-13-2014, 09:25 AM | #8 | |
Stop the hate, get a V8
3850
Rep 8,625
Yes. BMW doesn't just put things there for no reason. Pressurizing the airbox is a very important thing.
Past: 2011.5 M3 sedan ZCP |
04-13-2014, 09:34 AM | #9 | |
Rep 3,482
That wasn't sarcastic, I'm actually curious.
BMWCCA:518970 |
04-13-2014, 10:03 PM | #11 |
Rep 3,633
Yes, the hood vent is an escape not an intake of fresh air. Air enters through the front grill and left side lower bumper and goes through out the hood vent.
04-13-2014, 10:08 PM | #12 | |
Rep 3,742
04-14-2014, 09:04 AM | #13 |
3850
Rep 8,625
You can see the effect if you just washed the car or it rains. Sometimes it will spit water out the opening.
